05-15-2013 07:50 AM
05-15-2013 10:10 AM
05-15-2013 12:29 PM
05-15-2013 01:25 PM
05-26-2013 09:38 PM
"cybereality" wrote:
Yep, it's just about the Windows sound settings as kingtut mentioned.
Additionally, if you are using an Nvidia GPU you can go into the Nvidia control panel under "Display" click "Set up digital audio" and you can disable HDMI audio. AMD may have something similar.
11-12-2013 02:04 PM
11-12-2013 02:51 PM
12-22-2013 10:26 PM
"kingtut" wrote:
With the rift plugged in and powered on, go to Control Panel -> Sound. You'll see 4 tabs, the leftmost is "Playback" - select it. Click on the 'Speakers' item for the normal High Def Audio, and then click on "Set Default". For future-proofing, Right-click on the Rift audio device and select "Disable".
