05-15-2015 03:17 PM
05-15-2015 03:48 PM
05-15-2015 04:54 PM
05-16-2015 12:47 AM
05-16-2015 10:20 AM
05-16-2015 05:03 PM
05-16-2015 05:09 PM
"mappy24" wrote:
After updating to 0.6.0.0, I get to the Windows login screen but the system crashes during login, the error message is SYSTEM_SERVICE_EXCEPTION (EtronHub3.sys).
05-16-2015 06:16 PM
"DeanOfTheDrivers" wrote:
@msm903, if direct mode is working fine, why use extended mode? With 0.6 go with the mode that works for you, they should be latency and functionally equivalent. Extended mode is just a fall back if direct mode doesn't work for you.
05-17-2015 08:07 AM
This would suggest an interaction with the tracker. We'll need the minidump from the system crash. Sorry for the system instability.
05-22-2015 03:15 PM
