Application updated to SDK0.7 submited and approved, but...
viewportviewport Posts: 82
edited December 2015 in Oculus Share
Hello,
Our application has been updated to SDK 0.7 and is approved by Oculus Share. However still shows "pre-0.6.0"
Application name: Viewport Point-to-Point Experience
Version: 1.1
Submitted Date: Thu Jul 30 2015 13:46:24 GMT+0000 (UTC)
Thank you Very much.
    Which SDK or integration did you use?
  • viewportviewport Posts: 82
    Oculus Utilities for Unity 5 V0.1.0-beta and Unity 5.1.2p2
    Already tested in SDK 0.7 / Windows 10 and working smoothly.
    Thank you.
  • kevingullingkevingulling Posts: 86
    No option during submission for post-0.6 applications. (Or for that matter pre 0.6, it automatically calls it pre-0.6)
    Come on guys... This is so lazy that you make me look good. :lol:
    I'm checking on this for you guys. It's possible there is a bug.
    Thank you Cyber, happy to help somehow if there is a bug from any side.
    Looks like there was a bug, but I've been told it was fixed.
    You can try resubmitting the game with the same zip file and it should correct itself.
    Thank you Cyber, Ill do it right now.
    Files has been resubmited again. I Hope it fixes the issue soon.
    Thank you.
    Application has been resubmited and approved twice and still shows PRE 0.6.
    Could you please change the status manually? Thank you.
    Version: 1.1
    Bt the way I would really apretiate your help through this way, since I have wrote 3 emails to Oculus Developer Suppot whitin 2 months and nothing really happened.
    I can check tomorrow.
  • I've had a similar problem.
    we submitted an app called World of warriors VR experience (ID:1442921607259s6gsvhrggb9) which has now been approved but it's not showing up in the store. I didn't receive an email either to say that the app was approved so was unsure if there was another step the the process before making the app available on the store?
    thanks.
    The website is cached, so it could take as long as 24 hours to appear after being approved.
    I can see it on the site now, so I assume everything is OK.
    Hello, our new application called ¨Viewport Real Estate 360 Stereo Photography¨ has been just released in Oculus share, but once again is displaying SDK "pre-0.6.0" but is actually ¨using 0.6.0+¨
    (Oculus Utilities V0.1.3.0-beta and Unity 5.2)
    Last time we were running into the same issue with a different application, and it took more than 2 months and 3 different submissions to fix it.
    My understanding is the problem was fixed at the end manually. Is it any chance to fix it manually again?
    Thank you very much.
    https://share.oculus.com/app/viewport-r ... hotography
