Device: Galaxy S6 (SM-G920P)
Android Version: 5.1.1
Carrier: Sprint (But not activated/Wi-Fi only)
Details: Fresh, Factory-reset device. 24GB available.
I received my Gear VR this week, but I've had no luck in getting it to run. I put my Galaxy S6 in, and it completes the initial install, lets me login to my Oculus account, but will not install any of the Oculus apps or update "Oculus System Activities" once I reach that step.
Once it gets to the "Oculus 360 Photos" app, etc, it just starts erroring out. When I tap "Update Now" for the "Oculus System Activities" update, it appears to download something but it never actually updates. So, I'm stuck in a loop of nothing working. Plugging the phone into the Gear VR just shows me a message that it needs software installation to finish on the device.
I've tried everything I can think of: I've done an on-device factory reset, I've restored the device with Samsung Smart Switch, I've uninstalled the Oculus apps and tried again after restarting- nothing.
The only anomaly I can think of is that I do not have an active plan assigned to the S6 and it's wi-fi only (it's a work/dev device and does not have a carrier plan, although it is a Sprint device). The only thing I can imagine is there is a specific carrier setting that would require an OTA update to support the Gear VR... but that's a stretch IMO.
Overall I'm really disappointed and sad I haven't been able to get anything to work, or find anything online about fixing it.
Can ANYONE help me figure out how to get this working? Is there a way to adb the "Oculus System Activities" update onto the device? Or a way to update that doesn't rely on the system that isn't currently working?
Thank you.
0
Have you tried plugging your S6 into your computer after the Update Required message shows up to do an adb logcat to see if there are any interesting messages saying why it won't work?
All updates via wifi.
Connection to Mac only to download videos and built apks for testing.
after a while i tried to connect my gear vr innovator edition to my note 4 again.
it does not recognize the phone at all.
i am using the carrier free german firmware 5.1.1 and made sure the phone isnt muted
i tried to connect the micro usb as good as possible but it wont make any connection.
what else could i try?
I've also uninstalled/reinstalled/factory reset several times with no success. It is also running the latest firmware/software (Android 5.1.1)
At this point Oculus Home is just failing every install, but I managed to get "Oculus System Activities" and "Oculus Cinema" installed by installing the APKs manually.
If anyone has the APKs for Oculus360Photos, The Cirque de Soilel, VR Intro and Strangers with Patrick Watson...I might be able to brute force this stupid thing to work.
You don't have to message me, I know what the problem is not (see below).
Thanks.
I might have deleted some services but flashed a full image and did wipe everything afterwards.
I will try checking it with other phones. Maybe it is the gear vr. I doubt it somehow cause there is not much that can get broken IMHO.. .
Were you able to fix your issue?
July 24, 2013: READY
August 30, 2013: PROCESSING
September 9, 2013: SHIPPED
September 12, 2013: ARRIVED
https://support.oculus.com/hc/en-us/art ... -software-
Still, upon full reinstall, when I launch the Oculus App it immediately transitions to a screen titled "Update Required", with a description "Your Oculus software needs to be updated to the most recent version". "Oculus System Activities" needs to be updated.
When I click "Update Now", the update downloads in the background. There is a download spinner visible on the Update Button. When it finishes, the spinner goes away, but no confirmation is displayed at all. My only option is to try Updating again.
Since I can't use Gear VR without updating, this has effectively bricked my device.
Hardware specs:
Galaxy S6
Gear VR Innovator Edition
The Gear VR and S6 were working perfectly a few days ago.
I'm glad it's working, but it would have been really nice to have been able to skip the mandatory update prompt.
Do you recall anything that happened a few days ago (software update, new app installations, etc.)?
In Settings -> System Update, it said the last system update was on December 21 (before I had the Gear VR). I just checked to see if any updates are available, but there aren't any. (The "Auto-Update" switch has been off the whole time.)
Does the Gear VR require that you have cell service, not just functioning wifi? I can't find that documented anywhere, and it doesn't really seem logical.
that's not my experience since I have exactly the same model phone with service and it works just fine despite being a Sprint phone.
why would it need cell service to function? isn't wifi sufficient?
