Audio set to "HEADPHONES Rift Audio" why does it not automatically switch !
cbparker100cbparker100 Posts: 3
I have had my CV1 for a few weeks now, enjoying the experience, already completed Adr1ft.
BUT... is it possible to make the Headphones operate only when you are wearing the HMD and then revert back to your default playback device. I know I can do this manually, but it would be nice if it was automatic as there is already a sensor to detect when you are wearing the HMD ?
    Yes, that is how it's supposed to work. If it's not, then something is wrong. Can you provide these logs?
    https://forums.oculus.com/community/discussion/33792/how-to-get-logs-for-bug-reports-for-consumer-rift-1-3
  • whoa182whoa182 Posts: 381
    Have you tried re-installing audio drivers?
    CPU: i5-4690K 4.50 GHZ RAM: 8.00 GB Corsair Vengence GFX: Nvidia GTX 970 HDD: 2TB MONITOR: Samsung U28D590 27" 4K Res
  • cbparker100cbparker100 Posts: 3
    I thought it was a bit strange  :|  Not a big issue just a couple of clicks to fix.
    File Attached, cybereality
    A bit more info.
    I have a Sound Blaster Z for my Speakers.
    Checked driver whoa182, W10 reports under control panel that it's the latest, properties are :- 29.Oct.2015 10.0.10586.0
    edited April 2016
    Does this happen with one particular game? What about if you don't open a game but just put on the headset and look at Home (which does have some ambient sound). Does sound return to default after taking the headset off? Does the headset screen turn off when you take it off?
    Just uninstalled an re-installed audio drivers and it is now switching between HMD headphones and speakers correctly.
    Not sure what fixed it, thought it was odd !
    Thanks for your response cybereality + whoa182.
     Now back to Technolust...!
  • ron789ron789 Posts: 1
    I was curios about, which headphone should I choose for the the VR experience, mainly between Sennheiser PXC 450 and Audio-Technica ATH-ANC7B, I found them on this site Headphones helper
