Distorted sound makes games unplayable - S7 Edge
JAXbeachBUM
Honored Guest
I've tried playing ESPER2 and Gunjack, but the sound is so bad that both are unplayable.  I hear pops, chirps, and what reminds me of what music from a dirty CD sounds like. No Issues with Netflix or Milk VR.  Seems to be happening only on games so far.
I've already tried reinstalling the oculus software and games, and there are no other apps running.  Anyone run into this and fixed it?
4 REPLIES 4
coolaudio
Protege
is it a enyos or snapdragon that you have..s7?
coolaudio
Protege
fine here in UK with enyos and s7 edge
coolaudio
Protege
also try closing all other apps in case it makes a difference ..
JAXbeachBUM
Honored Guest
Galaxy S7 Edge, running Android 6.0.1.  All other apps are already closed.  Starting from a fresh reboot of the phone has ZERO effect on the sound quality.  Reinstalling the software had no effect, either.
