"Rift Headphones" Audio Device Missing
lord_omegalord_omega Posts: 9
My Oculus Home sound is coming out of my speakers instead of the Rift headset. The Home 'VR Audio Output' is set to "Rift headphones".
The Rift Headphones device is missing from Playback devices in Windows.
I tried re-running the Rift device setup. Now it won't get past the sensor setup part - it just keeps saying "Check Your Setup". I am already 2-5 feet from the sensor with it tilted up toward my face.
Any ideas?
  • lord_omegalord_omega Posts: 9
    edited June 2016
    Ok I got the sensor setup again (on my 12th try, I had to sit right infront instead of standing this time). Audio is still coming out of the wrong speakers though...
    Under Windows 10 Device Manager>Audio inputs and outputs; "Microphone (Rift Audio)" is showing, but not headphones. Scanning for hardware changes doesn't help.
    I fixed it by running C:\Program Files\Oculus\Support\oculus-drivers\oculus-driver.exe
  • nikoshaknikoshak Posts: 2
    Thanks lord_omega. I've had the same persistent problem, especially after every mandatory driver update Oculus has put out. Your suggestion seems to be fixing my situation consistently.
  • lepterlepter Posts: 62
    I would if the execution file was present in the folder but it isn't there. Disabling the headphone shouldn't remove it from the system. Having to do a full reinstall to see if that will re find the hardware.
    Well.....that didn't work so I bit the bullet and did a install of windows 10 thar I was putting off till the summer. All issues sorted. Don't know if it was a quirk of windows 7.
  • starpilot149starpilot149 Posts: 9
    Thanks man. I've had this problem for a few weeks and that worked for me!
  • MAC_MAN86MAC_MAN86 Posts: 1,318
    Here's a cool ICON for the Rift.
  • fariazzfariazz Posts: 79 Oculus Start Member
    I'm experiencing this same issue but manually running "oculus-driver.exe" didn't help. Have people found any other solution?
    Virtual Reality Mini-Degree - Learn to code in Unity and build 15 VR games and experiences
