I have tried and tried to get this thing to work. Set up went fine and as soon as it came to the screen to put the headset on and continue nothing worked. The light on the headset is yellow and not white. I have tried everything, unplugging, redoing the software from the website, everything. Can someone please help me with this??????
go to Oculus Home, click the cog in the top right and select settings.
then select devices and see what it says at the side of the rift
if it says something about the HDMI cable not being connected, just carefully unplug it and then plug it back in.
Don't ask me why, but i had something similar and it looked like my graphics card had just got into an odd state, even tho i had power cycled a couple of times.
Have you tried taking the facial off and unplugging the HDMI directly from the headset and then try plugging it back in again? Here's my video on how to https://youtu.be/TfTOLf5aAl0
the farthest i have gotten on the set up is where you check the lemses. Not sure where oculuc home is??????? I am now on my second oculus and same issue
