Oculus Rift sound question
IamTIamT Posts: 2
Hi, after I'm done using the Oculus Rift CV1 and closing Oculus app sound from my pc is still coming trough the Oculus headphones. Is this normal? Do I have to unplug The Rift every time I'm done using it? Thank you.
  • TwoHedWlfTwoHedWlf Posts: 2,234 Valuable Player
    Just go to your audio devices and set whatever device you want to use to the default
  • Freddy888Freddy888 Posts: 47
    edited November 2016
    Yep - right click on the little loudspeaker icon in your task bar to the right and then click playback devices. Then set it to whatever you need.
  • SakkuraSakkura Posts: 267
    For me it switches automatically though. Unless I'm using SteamVR, then I have to manually switch to Rift headphones and back again afterwards.
