Upside down sensor tracking problems
CrymsonMACrymsonMA Posts: 6
In preparation for the Oculus Touch and to improve my tracking area, I 3D printed a ceiling mount for the Oculus sensor and mounted it upside down in the corner of my ceiling.  It looks great, but when I put the headset on, the tracking is inverted (ie. Up=Down).  I know this is due to the sensor being upside down, but I have seen other posts of people using upside down sensors without issues.  Any help would be greatly appreciated.
  • maxpare79maxpare79 Posts: 1,783
    really if this is the case it's going to be a problem for my setup as well when Touch arrives...that was my plan...maybe @cybereality can chime in...
    I am a spacesim/flightsim/racesim enthusiast first :-) I7 [email protected], 16gb RAM/ Asus 1080 Strix Former DK2 Owner/Gear VR owner/CV1
  • neddycgoonneddycgoon Posts: 50
    There will be an invert option somewhere Ive seen folks using these without issue.Maybe ask Reality Check VR dude on youtube his are upside down.
    there is an option when you select your sensor in Home to reset Default view...that might be it?
  • kojackkojack Posts: 6,383 Volunteer Moderator
    I just tried that. Resetting default view didn't help, my sensor won't work upside down either.
  • CrymsonMACrymsonMA Posts: 6
    I reinstalled Oculus home and that seemed to resolve the issue.  Thanks for the support!
    Sakkura said:
    The alternative solution would be to move to Australia.
    That's where I am and it's not working. :)
  • YoLolo69YoLolo69 Posts: 1,129
    Mine is on my desk and I used an extension originally for GoPro to extend it between its feet and the sensor (around 28 cm, up and down screwing compatible with sensor and its feet)). With such flexible thing you can mount on ceiling and keep it straight as usual. In any case if reinstalling software is enough that's solve this for good ;)
    I7 3770K OC 4.5GHz, GTX1080 OC 10%, 16GB DDR3 2448  OC, Oculus Rift CV1
