I'm having some issues. I've had my Rift for a few months now. But for a few weeks now it has been unplugged and put away. I have just got it back out to play and it will not power up. I have the power adapter connected and plugged into the wall, I also have the USB connected. I do not have the HDMI in yet as I wanted to get it powered on before disconnecting my current secondary monitor. Any ideas? If there is any other information you need please ask. I will continue to try and get it working.
A quick question. I am hearing rattling inside the box unit, (The bit with all the connections; USB, HDMI, POWER, ETC). Do I risk breaking any returns policies or warranty if I open this up to take a look?
I've got a feeling I know what might be wrong. Before I put it away I had it sat next to me plugged in, and I remember hearing a very loud pop/bang. I assumed it was a fizzy drinks bottle behind me. I've got a horrible feeling that it was the Rift. Surely I must be covered for a replacement? It blew itself up!
Yup, that sounds bad. Maybe a short caused a capacitor to blow. The control box should power on without USB, HDMI, or DVI connected. I believe you can contact support for replacement.
Just thought I would give a little update. I have contacted support, and they have offered me a replacement. They are going to supply me with a return shipping label for the faulty unit, and they have put me in queue for a new one.
Hi, Got my Oculus Rift today, unpacked, followed the steps -- it does not power on. There is no blue light coming on anywhere. 🙂 Please assist. Thanks. Sheikh 917-693-5793
got a second hand oculus go from cex and when i went to use it would not go on wifi becuose it was joined to some one elses account so i do a factory reset on it and now it wont power back up and it seem not to be chargi ng even tho the orange lite flashes can you please help
Get Help
