Better than the guardian system
cybernettrcybernettr Posts: 939
 I had my oculus touch set up and I was playing the bullet train demo the other day and I noticed that every time I moved ever so slightly when I was in the train car, the Guardian system guidelines appeared.  This despite the fact that when I set up the guardian system, it said my play area was "moderate."  I couldn't even shift my weight from one foot to the other without the guardian guidelines appearing! It was very immersion breaking!  This is how I resolved the problem:
I have a chair mat on my floor in front of my computer desk to protect the carpeting.  If I take off my shoes (or house slippers) and stand right at the edge of the chair mat, I can feel it with my left foot. This has the added advantage of taking me away from being right in front of the computer screen.
I turned off the Guardian system completely.  I don't need it, because I know exactly where I am because I can feel the edge of the chair mat with my left foot.
This ties in with a clever idea I read on C/Net or somewhere.  If you are playing on a hard floor, you can get a throw rug that is roughly the size of your play area.  That way, if you play in your stocking feet, you can always feel when you are in the safe zone. If your playing area is already carpeted, you can buy a couple  of chairmats from the office supply store to define your safe zone.
Physical safeguards like this will probably be better than the guardian system for most people.  Hope this idea helps someone.
  • benplacebenplace Posts: 769
    I have no problems with the guardian system myself, it works perfectly.
  • cybernettrcybernettr Posts: 939
    I'm sure it depends a lot on your individual setup and the size of your play area.
  • HoIIywoodHoIIywood Posts: 326
    edited December 2016
    And what you are playing. When you're face down getting shot at, feeling around with your foot isn't always the best method.
    I suggest you seek new girlfriend and ensure during the twenty questions part of speed dating, that you clarify she A) Knows what VR is and B ) Is happy to act like the old drunk guys at the edge of a mosh pit whom push the young kids back in when they get loose from the flow and stumble out of the pit.
    She can be your Guardian...ANGEL!
  • jayhawkjayhawk Posts: 824
    I had that problem and reran the guardian system this time running right along the walls to make it bigger. I didn't do that before because I wanted a bit of a buffer before I hit the wall. Now I don't have that issue. I'm guessing the guardian will show up once you get into a certain proximity of it regardless of how big your play space is. You can just turn off the walls but leave the floor outline on. I think they need to update guardian with the option to adjust opacity for the grid. Leave the floor outline bright and leave the circle that forms when you get close bright.
  • n3cr0-0n3cr0-0 Posts: 186
    I just turned off the walls but still use the guardian system... no more grid in my face.
    I would but can't trust it..it moves around sometimes on it's own
  • Map63VetteMap63Vette Posts: 141
    My bigger concern is the walls or objects.  A carpet doesn't exactly fix that.  It would give me an idea of where I might be in a room, but not how far I can reach.  I've actually been pretty impressed with the system and think it's pretty cool.  I'll reach out and see just how accurate the "walls" are and it's pretty good.  I think they shrink it back just a few inches to make sure you don't smack them, which is a nice touch.
  • HiThere_HiThere_ Posts: 1,277
    What Guardian does, is inconsistently warn you when your body is moving too close to a border, and it does it more or less closer to that border depending on how far your hands are from your body.
    What a rug does, is consistently warn you when your body is moving too far from the center of your VR space, regardless of how far your hands are from your body.
    And that makes a rug better because :
    - If you can feel the rug under your feet, that means you have enough arm clearance to throw a ball (or stick of dynamite).
    - If Guardian doesn't trigger, that doesn't mean you won't bash your hand into the border half a second after the Guardian walls do trigger to warn you you're throwing your arm beyond the border by throwing a ball (or stick of dynamite).
    I use both : The rug, and the Guardian as an extra precaution. But because I'm using the rug, the immersion breaking Guardian walls NEVER kick in for me, unless I want them to (by moving off the rug on purpose).
    And if I could use only one or the other, instead of being able to use both : I would definitely choose my rug over Guardian.
  • Percy1983Percy1983 Posts: 1,410
    I haven't got much room so I plant my feet, swing my arms around and if I don't hit anything I don't move.
    Asrock Z77 Extreme 4 + 16GB RAM 1866mhz + i5-3570K at 4.5Ghz + Coolermaster Nepton 140XL cooler
    Sapphire 8GB RX 580 Nitro+
    256Gb SDD Samsung Evo 850 +3x2TB in raid 0 with 64GB SSD cache
    Thermaltake Level 10 GT Snow Edition + Toughpower 875w
  • AndrewJ71AndrewJ71 Posts: 280
    +1 for turning off the Guardian walls and leaving on the Guardian floor.
  • DreamwriterDreamwriter Posts: 1,101
    The walls are important for getting your attention, though - I don't watch the floor when I'm going to catch a football in VR Sports Challenge and need to jump to the side to do it :)
  • Vic20Vic20 Posts: 54
    I use a similar method now instead of the Guardian. I use a small mat and place a pen under the mat facing the PC so I know where I am.
    although the walls are not there the display still blacks out if you venture too far; I have enopugh room so I just set the boundaries well away from things that are breakable (for instance my computer since it's out in the open with a bunch of liquid tubes everywhere)
    Much more immersive with zero gimmicks
  • ElunedraElunedra Posts: 87
    i had the same problem with the guardian system, it feels like i am standing in a small cage, but after playing for like 30 minuts it became natural,and it didnt break immersion so much
  • Baz_uKBaz_uK Posts: 136
    This, my room  is small and guardian was pretty much on all time,  so just use floor line now....easy fix. However my room is so small I can't move anyway....so I just don't!! I know it sucks,  but I have never hit anything- yay
  • bluenose1875bluenose1875 Posts: 13
    How do you just turn of the walls ?
    Open the Universal Menu (Oculus/Xbox button) and look on the bottom of the menu on Guardian Settings.
    In that case a good solution would be to define the Guardian zone with the size of a small central rug, then turn off the walls.
    This has the intended effect of only tracking your headset (not your hand controllers), and triggering a warning (by blackening out the display) when your headset moves too far away from the center of your VR space.
    Which guarantees that if the display isn't darkened, it's because you are far away from your room borders and have full arm clearance. Which is precisely what the default Guardian wall mechanics fail to guarantee.
