Sensor issue help
bl4CkCharizardbl4CkCharizard Posts: 1
hi I'm new here so I hope I posted this in the right place but I got a oculus this Christmas and it was working fine but now the sensors aren't working I keep getting no sensor connected on both of them, I tried to repair it I tried unplugging them and putting it back in that didn't work I reset my PC, I also turned off my PC then I completely reset the hole PC  put I keep getting the no sensor connected  when it was working fine a few days ago. I also looked at the cords to see if one of the dogs or cats chewed on them but they are fine. I don't know what to do anymore
Answers
  • Iceburn26Iceburn26 Posts: 8
    How many sensors are you using? Are you using usb extension cables also?
  • Bruno_BGPBruno_BGP Posts: 24
    Mine has stoped to. I just have one. Tried to reseat the usb cable, change to some 2.0 ports but still dead.
