02-05-2017 06:46 AM
Hello I received my rift from amazon today and was excited to get it set up and use it but after plugging everything and running the setup I'm stuck and I don't know what to do.
After the rift downloads and installs the software I get this when it tries to launch the oculus home application "GetThreadCount failed" and the software doesn't launch.
Getting back to the rift it says in the software "put your headset on and adjust the lenses" but I get nothing displaying the led inside the headset is white.
Anyone know what to do?
My PC specs are:
I5 6600K 4.5GHz. GTX 1060. 16 GB DDR4 RAM. Asus Z170-a Motherboard.
Checking event viewer I see this
"The description for Event ID 0 from source OculusVR cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
05/02 14:13:41.129 {!ERROR!} [Kernel:Error] Camera frame truncated"
02-05-2017 07:19 AM
02-05-2017 05:55 PM
02-05-2017 06:34 PM
02-05-2017 09:29 PM
