Oculus Rift - Everest VR does not load
sKw7910sKw7910 Posts: 3
While it is loading complains that 'Oculus authentication failed ..Please login into store and make sure Everest-Vr in library' .
I have successful login and even tried logout and login, other apps are working fine and updates are happening. Also I have enabled unknown sources.
  • cyberealitycybereality Posts: 23,033 Oculus Staff
    Try disabling anti-virus.
  • sKw7910sKw7910 Posts: 3
    It did not work
  • lekjart2lekjart2 Posts: 6
    Solfar Dev here. We are looking into this with Oculus. Seems to be some error within Oculus runtime for some users/setups. We are busy tracking down exactly what specific circumstances cause this. Will keep you updated as soon as we find out.
    Good news, we probably have found a fix. The problem came up with users that have an unusually long path variable in their system environment (1K+). Some middleware we are using didn't handle that edge case correctly. We will create a patch and update the client as soon as we have tested it and made sure it runs fine. Probably in 12 hours or so if all goes well.
    Sorry for the inconvenience.
    Thank you for the quick response.
    New update is live and should resolve the problem. Please let us know if you encounter any further problems related to this.
    Cheers!
    Thank you. It fixed the issue.
  • hayesabernathyhayesabernathy Posts: 2
    Everest vr won't start...Anybody know why?
    We downloaded the update and it still won't start.
  • mikoramikora Posts: 1
    edited August 14
    same here. everest vr doesnt start. i hit the play button and then nothing happens.
