Oculus home graphic problem and other apps
minos90minos90 Posts: 2
Hi, I don't know if I am the only one having this problem... but in Oculus Home, when I move my head from side to side there's some graphic problem... it's like some little part of the screen gets freezed for a micro second.... Its a similar effect like the one you get when the vsync is off in a game.. but more disturbing... it happens on that screen specially and another apps.... in oculus video app for example I didnt notice the problem...
Sorry for my bad english . And thank you
  • kavangekavange Posts: 21
    Yes I have that too and it's actually a lot worse now with android 7. Hopefully there will be an update at some point.
  • minos90minos90 Posts: 2
    Thank you very much for your reply! It's true what you mentioned about Android 7!
    Hope they release a fix soon!
    edited March 2017
    AFAIK Android 7 is not fully supported right now, which may lead to strange issues like this.
    edited March 2017
    It's basically rolled out everywhere in the world now for S7/S7 Edge and it's been in beta 6 months before that.
  • Norman3DNorman3D Posts: 63
    Did you ever get this issue fixed?
    Android 7 is supported, I can guarantee that.
    That being said, I'm having the same issue on our game. Downgrading to Android 6 gets rid of the problem, but of course that's not a solution. The fact of the matter is that the vertical tearing is only present when updating the Samsung S7 to Android 7.
  • relaxculusrelaxculus Posts: 97
    how can i roll back Andoird 6 to my new S7? thx
