To start with I want to commend Oculus for providing RMAs for some
people with this issue who are outside of their warranty period. This is excellent customer service and a great way to keep brand loyalty and trust in the Rift as a whole. I feel
bad for those you have denied though for whatever reasons you have. It
is pretty unfair that apparently through no fault of their own their
Rift audio has died without any chance of repair or an option to buy a
replacement ribbon cable to attempt repair themselves.
Can Oculus give us some information about why this is happening to some users?
Is
it a fault with some Rifts during manufacturing or are the users doing
something that increases the chance of this internal ribbon cable tearing?
Is there anything we can do to avoid this happening to us?
Should we be avoiding stretching the headband springs too much?
This
is pretty critical because Oculus still have no paid spare parts or
repair service. If we inadvertently break our Rifts through normal use
when out of warranty we are shit out of luck and have to buy a brand new
headset or switch to an external set of headphones. Unless of course your support staff decide to provide an RMA outside of warranty which appears to be about a 50/50 chance from the 36 posts I read.
I did some
searching on this topic on both reddit and these forums and found about
36 posts on the topic since June 2016. 16 of these posts occurred in the
last 3 months so it appears to be something that is getting worse with
time. If this happens to more and more people when out of warranty this
is going to be a large PR problem. That said 36 posts of the however
many tens/hundreds of thousands of Rifts out there is quite small in the
big scheme of things too. Having a way to fix it ourselves by buying
a part if out of warranty would be great for piece of mind though.
Do you have any plans for spare parts service?
Some clarity on the issue would be great to be sure we treat our expensive excellent VR device with the care it deserves.
Possible causes
I'm
wondering if the underlying cause is the tension springs in the
headband itself somehow catching on this internal ribbon cable causing it to
tear. Maybe repeated stretching of the headband springs over time causes
the ribbon cable to move into a position where it can tear inside the
headstrap?
Springs here
https://www.ifixit.com/Teardown/Oculus+Rift+CV1+Teardown/60612#s126787Springs in action as this person stretches the tension springs to put it on
https://j.gifs.com/AnBwW3.gifIf
this is known to cause the problem could Oculus let us know so we
stop doing it as much. I'd much prefer to avoid doing whatever it is
that can cause this ribbon cable to tear than run the risk of it happening when I get
out of warranty.
Some pics of the torn ribbon cable from various postshttps://forums.oculus.com/community/discussion/comment/525398/#Comment_525398https://forums.oculus.com/community/discussion/comment/531518#Comment_531518
CPU: i5 6600K (conservative overclock), GPU: Asus GTX1080Ti (not overclocked), motherboard: Asus Z170 Pro Gaming, USB Card 1: Inatek 4 Port, USB Card 2: Startek 2 Port
Original images sourced from iFixit Teardown
Modified images here incase the Oculus forums shrink the pictures down too much.
http://imgur.com/a/fJboz
If anyone has a dead Rift I'd love to see some close ups of these two areas.
Where do they connect to the mainboard?
Are they one long ribbon cable or is it in a few parts with junctions across the entire headstrap?
Also what does the ribbon cable do at these possible fracture points while flexing the tension springs?
As likely most others who had this happening, I didn't do anything "special" to my Rift and neither is my head unusually big or something which would stretch the band beyond "normal". Just normal use of Rift really.
Whether the ribbon tears on the indicated location...I don't know. I have seen pictures where the cable broke right where the connector is, near a small board in the Rift.
If there is something we as users are doing which might increase the chance of happening I think it would benefit both Oculus and the consumer to know to avoid a particular action with the Rift. The less Rifts ending up with this problem the better for both users and Oculus.
Without a doubt Oculus would know what is causing this issue by now. Whether or not they have managed to resolve it in the design or production line who knows. Less than a month ago I know of one user who had to RMA a new Rift that exhibited this same issue only after a week of use. So it still happens with new Rifts.
As a victim of this issue can I ask did you put on the Rift by fully extending the tension springs as shown in the this gif?
I never fully extend the tension springs when putting on the Rift. I just slide it on my head with minimal flex on the springs.
Regardless of how widespread the issue is I still think it is completely unacceptable that there are no user paid repair options or spare parts available almost one and a half years after launch. I've been banging on about it for over a year and many are likely sick of it. I can guarantee though if a minor hardware problem arose with someone's Rift and they had a the choice of buying a replacement part or buying whole new Rift + accessories the choice would be pretty simple. Problem is that choice doesn't exist yet.
Sure Oculus might not want to officially support a spare parts service but how hard would it be too leak spare parts to a 3rd party. The market might not be profitable but it would give some peace of mind to Rift owners knowing that if something goes wrong out of warranty they can possibly fix it as opposed to buying a whole new headset.
Ribbon cables are always a weak point but are generally needed, wear and tear is the answer unfortunately.
Sapphire 8GB RX 580 Nitro+
256Gb SDD Samsung Evo 850 +3x2TB in raid 0 with 64GB SSD cache
Thermaltake Level 10 GT Snow Edition + Toughpower 875w
Poster of the week who never got a T-Shirt ;( dayum they looked tasty!
Do people think there is actually a problem with grease or something on the contacts or is this action just moving the ribbon cable around so it connects again? Ribbon cables are pretty delicate so I would think it is pretty hard to wiggle one back into a connection. Maybe a fleck of dirt is getting in between the contacts and this clears that out.
One other thing that occurred to me. Of the people who are being rejected for RMA they are being told to just use an external headset.
The problem could possibly be more than just missing audio though. This ribbon cable appears to also feed the tracking LEDs on the rear of the headset.
I'd be keen for anyone who experiences the missing audio issue to look at their Rift while it is on through a phone camera. As some tears could be only minor there will likely be a few users who will only be missing audio.
Do the tracking lights work on the front and back?
Image from (https://ifixit-pwa.appspot.com/guide/60612)
I get Oculus don't want to sell spare parts but I'd love to see this ribbon cable appear on ebay from some "mysterious" seller. Even at $50 it would be well worth it to breathe life back into some Rifts.
Edit: Also I have some more images of torn ribbon cables and a potato drawing of the shape of this cable as it leaves the headset. http://imgur.com/a/fJboz
Hopefully mine gets a warranty replacement soon. It's been there since Friday and i'm told it's being looked at. I'll report back on the status.
Oculus is probably gonna have that part heavily patented, and I doubt they will release that part or the schematics for it cuz of warranty and such, because releasing that part only would kinda come across as admitting there is a problem, which as everyone knows, is something business people don't like doing, even if the technical people there might
On the right side my sliding mechanism has a block at a certain point. I think that is where the friction on the ribbon happens. I try to avoid pushing through when I feek this "block".
Prevention: Never pull out the sliding part entirely and adjust it that way that it cannot slide all the way out.
There was a very good video of some guy somewhere where it was exactly shown what's happening, can't find it right now.
PS My experience with Oculus support, so far, is excellent. For another issue I sent in my unit, and the response and them sending back a replacement after it was received in NL couldn't possibly get ANY faster. (Scheduled delivery by UPS on Tuesday). (Basically, it arrived on Friday noonish in the distribution center in NL, and dispatched early Tuesday).
I was just hoping support could shed some info on how to replace it cause I would pay to have it fixed. Support replied there wasn’t any solution yet on how to repair and I should keep my eye on the forum incase one should ever arise from Oculus.
I plan on on buying a new Rift next month anyways, but I would love to get this one repaired some day.
Ouch you would have definitely lost rear tracking sensors there. Hopefully they do get a paid repair/replacement/spare parts service sorted soon so you can fix it. I've been banging on about it for over 14 months since back when they were telling people whose cats had chewed their HMD cable "Sorry buy another Rift". They have started offering them as spare parts now thank god but they still need to get their after warranty user paid support sorted.
You look like the perfect candidate for getting a close up pic of that cable. I've been trying to see how many traces there are on the cable. Can you take some close up pics of each end of the break?
I'm particularly interested in some idea of how many traces there are like the ones I highlighted here in green.
https://imgur.com/14mSxDe
It would be nice if Oculus could let people know if there was a way for us toavoid having this happen to us. Even tell us we're "holding wrong" would be better than having this sort of failure.
Time to contact support.
It's a shame a perfectly good headset is reduced to a paperweight if this happens.
I've never had any issue with my headset at all so far, but it makes me uncomfortable to know my number may come up at any time.
- Paid spare parts service
- Paid repair/replacement service
For those deemed outside of warranty the current solution offered by Oculus support of "Buy a new headset + touch + sensors" is a very poor way to treat loyal early adopters.At a minimum they should be offering these customers the option to pay to replace just the headset at a reasonable cost neutral price to Oculus. Pretty sure already have a headset only SKU as I recall seeing other users post images of them a while ago when they get RMAs.
In before we see people/support saying "Use an external set of headphones" The problem is deeper than that when this ribbon cable fails completely you lose the rear tracking LEDs. Once the tear starts it will end up tearing completely over time with repeated flexing of this cable.
External headphones are NOT a solution.
I treated my headset with great care and it happened to me too. I specifically avoided flexing those side straps because I knew this problem could arise. I rarely played high intensity experiences with me flailing around like a madman.
Prior to it happening to me I thought that maybe this was something that will possibly only happen to a small number of users. My number came up though and I'm a little more worried for others now. If this is an inevitable failure for all headsets this is going to be a major problem for Oculus.
I've been documenting threads on this issue for over a year now and currently have a list of 52 63 threads with users posting about this. Of those 52 63 threads there are multiple users posting reporting to have had the same problem. While still not too common it is definitely large enough to be a problem that I would hope Oculus has addressed internally with a design/manufacturing change even if they don't plan on publicly acknowledging it.
I'm currently on the first level of Oculus support and was asked to
Edit: I updated my list of users posting about this issue and found an additional 11 from the last few months on reddit/oculus forums (up from 52) . I have sent this list to support.
I've put together an unscientific survey to see if we can get some idea of how widespread this issue is. It also allows people without the issue to let their voice be heard as well. I encourage all users to fill it out.
https://docs.google.com/forms/d/15DWS5lVTzBGwrgs-kmewo9m7AjrWoSuZrNaX7yeXA8U
Done.
As I’m approaching the end of warranty period I was getting more and more stressed about inevitable, sound loss (yes, after 1st replacement I was hoping for construction improvements of this relatively wide-spread issue - but nope, second died too!) So this time I decided to mod slightly right spring arm with a bit of electrical tape.
What I did was, I fixed the arm in locked postion. The key is to fix it in the position it normally sits on you face and only use the left arm’s spring mechanism to put it on/off. You may need another person to help you with the tape while you’re wearing the Rift. There is no cable in the left arm so there’s no problem. So far its really good, its not loose as you would think. I hope that eliminating the movement of the right arm completely will solve this
damn problem.
This will not work if you have more than one user, obviously.
Pic:
Ref: https://www.reddit.com/r/oculus/comments/7v5d2a/preventive_audio_cable_failure_measure/
This method is similar to what wasyl00 posted however the tape only stops the right arm from moving further into the headset slide mechanism than it needs to. You still have the ability to extend it outward to fit the headset to new users.
Not as bulletproof a solution as wasyl00 by totally immobilising the slide completely but a better option as it does restrict the motion somewhat.
I really wish Oculus would fix this with a design change. I'm guessing they have done the maths behind the scenes and worked out it is cheaper to offer replacements to users than it is to publicly acknowledge the issue by making a design change.
Based on the survey I posted earlier people seem to expect these things to last at least 3-5 years before failing. Still a small sample set but in time we will get more results.
Yes this was actually my inspiration. Its a better solution than standard as it should limit some of the movement and also absorb that return impact of the spring, extending life of flex cable in the process (its all about fatigue prevention IMO).
If you check this reddit thread there is even my comment about permament fix.
I hope I will ride my modded rift until gen 2.
Would it not be possible to prevent this by hot gluing or epoxy down the ribbon to the board so it cannot be pulled on at the connection? you could still remove the cable but would require some razor work, might be worth while mod.
I think if someone figured this out it would be a one hell of a business idea with all of these faulty out of warranty headsets around that oculus doesn’t want to fix.
See this video which shows the failure of one cable inside the mechanism.
Then my potato drawing of how I think the cable routes inside the spring mechanism.
https://imgur.com/jfJvk1M
The middle black line is the fixed part of the spring mechanism attached to the headset. Then the lowest black line is the movable part of the spring mechanism. From the video the failure appears to happen at that last bend in the ribbon cable. The bend rolls up and down the length of the ribbon cable as the mechanism moves.
I've been trying to find a good piece of software to make a animated gif showing how that part works since I would not be game pulling apart my Rift to video it directly.
