Gear VR missing cards and crashes after Aug 29 update-- FIX — Oculus
HVS_ClaireHVS_Claire Posts: 200 High Voltage Software
edited August 2017 in Dragon Front
Hi players,
We are aware that some GearVR users are experiencing crashes and missing cards since the last update. This problem is easily solved by uninstalling and reinstalling Dragon Front.
No progress will be lost.
We regret the extra hassle this places on players, and we are working to find a more straightforward solution this issue.
Reach out to me personally if you need any help.
HVS_Claire
  • GipettoGipetto Posts: 2
    What did this update do exactly? I can't find information on it anywhere.
    A casual gamer. An intense leaner.
  • HVS_ClaireHVS_Claire Posts: 200 High Voltage Software
    Hi @gipetto,
    The update notes are posted on the website. I usually post them here too, but I suppose I missed this forum this time. Sorry about that.
    Update as of August 29th, 2017
    Rift: 2.0.4.0 | Gear: 2.0.4.0
    • No more Checking Online Content! All game content will now download from the Oculus Store (Gear)
    • Conquest challenge difficulty now more reasonable for new players.
    • Fix for Out of Sync error using Prince Will Yates
    • Fix for odd behavior under certain circumstances when receiving Portal rewards
    • AI adjustments to help with Gear freezes
    • AI difficulty reduced slightly across the board
    http://www.dragonfront.com/updates/
  • Laja28Laja28 Posts: 2
    Bonjour, il y a un gros problème sur pc oculus avec les touch sur windows 7 carte graphique 1080 gtx , le casque s'éteint et tout les écrans aussi dans les chargements dans dragon front , ce problème est uniquement sur Dragon front.
    @laja28 Bonjour, êtes-vous sûr que vos pilotes vidéo sont à jour? Question ouverte à tous les joueurs: d'autres personnes connaissent-elles ce problème?
    Hello, are you sure your drivers are up-to-date?
    Open question to all players: Are others experiencing this problem as well?
