Sound too loud at 10%
RiuujinRiuujin Posts: 1
So i turned the sound to 10% on my rift, in most cases this is oké but sometimes even this is too loud. Is there a way to lower it even further without muting?
Best Answer
Answers
  • SitruzSitruz Posts: 66
    If you have a keyboard with quick mute, volume up and volume down buttons, use those to tweak it. This will affect the Windows volume setting as beyondinfinity says.
  • antuanosantuanos Posts: 2
    I finally found a solution. Install the program Equalizer APO first and then Peace Equalizer. Then you can use Peace Equalizer to slide down the decibels further as much as you want. So comfortable to have any volume you want...
  • flashpirateflashpirate Posts: 17
    Agree. I keep my rift at max 20% and lose my hearing above that. Literally never went over 30%. The balance is nuts. Using an Oculus ready pc, nothing fancy.
  • Stryker1000Stryker1000 Posts: 489
    its a bit of a shame I cant increase the volume in my rift as hearing impaired and wish I could turn the sound up a little bit .
  • dburnedburne Posts: 3,506 Valuable Player
    Wow and here I am wishing it was a little louder, always run it at 100% and wish I could get a little more.
    Don
  • snowdogsnowdog Posts: 7,479 Valuable Player
    My hearing is screwed and I have mine at 30% volume which is perfect for me. The years of working in a biker's pub and being in a couple of bands has taken its toll on my poor lug holes :(
    I run E:D on BOOST and it rocks!!! Levels of the Rift used to be louder than they are now.
