problem with my Rift .. ( motion blur )
ColonelJAXColonelJAX Posts: 8
edited October 2017 in Support
hi ,
since i have it  i realize a motion blur in my headset and it appears with moving my head ,   happend to me in most apps i use  and its not so sharp
i found many many threads about this problem but i can't see any real solution for it  ,  please  i need help  and if you could access to my computer to check it or check vga card settings its ok for me
thank you
P.s ... here is a simulation example  for that issue , and motion blur which appear specially clear with texts when moving
Answers
  • cyberealitycybereality Posts: 23,455 Oculus Staff
    What you're probably seeing is the glare from the Fresnel lenses (aka "god rays"). This is normal and part of the way the physical lenses work, so there's not much you can do.
  • ColonelJAXColonelJAX Posts: 8
    well, thank you for your replay  ,  but i feel there is something wrong , this blur text and blur textures sometimes  make me feel that ,
    may be its something related to my card  ( Nvidia gtx 1070 settings )  or changing frame rate  or any stuff like that ?
    if you don't mind please i can give you any log you could need to confirm there is nothing missed or wrong configure to it  because its very annoying to me
    P.s for example  robo recall game  , when i look to my hand its little blur not sharp textures as i expected
    I doubt there is anything wrong. You probably just had unrealistic expectations. Rift won't look even as sharp as a 1080P monitor due to the way the image is enlarged by the lenses, and some other things. Especially it you are accustomed to 1440P phones or 4K TVs, Rift can seem low resolution in comparison.
    But feel free to submit a support ticket if you want to discuss this further. Thanks.
    https://support.oculus.com/
    thank you for your help ,
    https://support.oculus.com/   leads me to another page to choose rift or gear   then gear lead to many other options which i'm totally lost with it   ( i'm still new here )
    could you please give me direct link for support ticket ?
    Getting Help
    • Rift Support - Get help if you need support with your Rift.
    when i checked this link above , it gives me dead link  ( page not found )
    edited October 2017
    Can you let me know what URL that text is on (and/or post a full screenshot of the page) and let me know how you got there? You can submit a ticket directly here:
    https://tickets.oculus.com/hc/en-us/requests/new
    yes sure
    https://support.oculus.com/help/oculus/154179174933772/
  • elbofforelboffor Posts: 2,406 Valuable Player
    I also get something similar, but i think its just ghosring due to the screen. That said, it does only seem to happen during head movement and not video movement
    This is my forum signature.
    edited October 2017
    edited October 2017
