I have the "Public Test Channel" option selected in my settings, but the update won't download (as it's "Queued"). Nothing I have tried has made this download start.
If I click on "What's new" for the Medium update, it says that the update includes Dash compatibility, so it looks like it's waiting for the 'Oculus software update' to complete before it will install. The update for Chronos doesn't say much at all, but I suspect that it's waiting for the same reason.
How can I get the 'Oculus software update' to download and install? At the moment, it's blocking me from running the other two programs. I'd also like to play around with the new OH and Dash!
Occasionally, the 'Queued' message changed to 'Downloading...' and I get a progress bar. Bat after about 5 seconds it goes back to 'Queued'. Have left the PC for hours and it's still in the same state.
Try going to the library list and click on the menu icon (...) for the app then hit update. This got thr Robo Recall update moving which had been stuck.
Update completed now, nothing hanging.
i7-5820K @ 4.2Ghz, water cooled, Asus X99-Pro USB 3.1, 48 Gb DDR4 2400, Samsung 950 pro M.2 SSD, GTX 980 Ti SC, 750w psu
Unfortunately, the (...) is disabled, but I have noticed something new!
I sat and watched the screen for a while, and sometimes when 'Downloading...' appears it *does* actually download something (it managed to get to 3% once), then reverts to 0% and then back to 'Queued'.
Every time this happens on my system, I find that the only solution is to go through the "Repair" installation of the Oculus software. After that it works for an update or two, then it breaks again.
