Intermittent sound in right headphone whilst fine in left
m.a.searlem.a.searle Posts: 1
Hi
i have a rift, bought yesterday, and all but the right headphone works fine. I have checked my audio is set to rift audio, it has the dvd sampling rate set, might try cd sampling. When I move the headphone it sometimes come to life and then disappears when I move my head. It feels like a broken wire or loose connection issue rather than software. Any advice??
  • FastForward352FastForward352 Posts: 176
    I had the same problem, and I discovered that my left headphone sometimes unscrews on its own, it's sometimes just simple as that...
    Asus X99-A MB | i7 5820K @ 3.30GHz | Asus ROG-STRIX 1080Ti | 32 Gb RAM | SSD SAMSUNG 500Go M-2 |  Samsung 40" 4K Screen | T500RS & TH8A Shifter on Wheel Stand Pro | TM Warthog & Combat Rudder Pedals | Buttkicker Gamer 2 | OCULUS RIFT CV1 - 3 Sensor roomscale setup
  • bigmike20vtbigmike20vt Posts: 4,198 Valuable Player
    Ditto. After maybe 18 months on Thursday night my left headphone started cutting out. I was worried however 2 mins with a screw driver tightening up fixed it
  • klrichardsklrichards Posts: 3
    I also had the same problem with the left audio. Tried fast forwards suggestion of tightening the screw and it fixed it. Cool. Love the rift so far
