The oculus rift,sensors, and touch controls are green and checked but i see a orange light on the little sensor on the rift. drivers up to date window up to date usb is up to date
here is log file from %LOCALAPPDATA%\Oculus\
[Debug] [12/30/2017 6:01:20 PM] Starting up OculusSetup v1.16.0.0.
[Error] [12/30/2017 6:01:23 PM] Exception building substitutions!
System.DirectoryServices.AccountManagement.NoMatchingPrincipalException: The User object for the current user could not be found. You may not have access to it.
at System.DirectoryServices.AccountManagement.UserPrincipal.get_Current()
[Debug] [12/30/2017 6:06:00 PM] Installing 'Visual C++ 2013' redistributable.
[Debug] [12/30/2017 6:06:01 PM] Process C:\OculusSetup-DownloadCache\visual-cpp-2013.exe exited with code 0 (success).
[Debug] [12/30/2017 6:06:01 PM] Installing 'Visual C++ 2013 x86' redistributable.
[Error] [12/30/2017 6:06:23 PM] Process C:\OculusSetup-DownloadCache\visual-cpp-2013-x86.exe exited with code 1618 (failure).
[Error] [12/30/2017 6:06:23 PM] Error installing redistributable Visual C++ 2013 x86: Daybreak.Redists.RedistInstaller+RedistInstallerException: Redistributable Visual C++ 2013 x86 returned an error ---> Daybreak.Util.Mixins+ExecuteProcessException: Process returned an error: 1618
at Daybreak.Util.Mixins.ExecuteProcessMixin(String path, String arguments, List`1 additionalExitCodes)
at Daybreak.Redists.RedistInstaller.InstallRedist(String redistName, String exePath, String redistParams, String redistId)
--- End of inner exception stack trace ---
at Dawn.Setup.InstallRedistributablesStep.InstallImpl()
