Sensor Setup Problems
chillyboichillyboi Posts: 1
Tried to move my sensors to get a bigger play area, my sensors are a couple feet apart from each other and one of them is not in front of the other, yet the setup looks like this: https://gyazo.com/cdff3e1d728bed1447ca6db957d6346e
Any help would be appreciated.
    See this article with some guidelines for setting up the sensors.
    https://support.oculus.com/1814957818761397/
  • alan_worthalan_worth Posts: 8
    I have a one sensor system that has been working fine until a few days ago. I have re-installed Oculus, updated all drivers, moved cables, etc., and this problem won't go away. Any ideas?
  • RedLeader42RedLeader42 Posts: 44
    Try replacing or swapping cables, unless that's what you meant by "moved".
    I tried to cheat and use a USB 3.0 extender for the third sensor as my other two sensors were separated on the 3.1 controller anyway. It worked for like 3 days then decided to never work again. I fell back to the 2.0 extender the sensor came with, and it's been solid ever since.
