Oculus Rift one of my two sensors not working. HELP :(
JoshSkolnick97JoshSkolnick97 Posts: 7
One of my sensors is working perfectly, however my other sensor is not being recognised in any of my USB ports (2.0 or 3.0), including the ones which i've had my working sensor connected.
    WHen in Oculus Home, can you post a screenshot of the device's screen?
  • JoshSkolnick97JoshSkolnick97 Posts: 7
    I forgot to mention, i've just upgraded my computer with a fresh install of windows. Prior to upgrading both sensors and touch controllers were connected. I just cannot complete the setup yet due to the sensor not being recognised at all.
    When you plug both sensors in, can you do a screenshot of the device manager, please?
    edited February 2018
    It seems that my computer doesn't even realize it's connected.. I tried all USB ports but no luck again.
    Can you try 2 things
    First, run set up again, and choose REPAIR
    or try and run
    \Oculus\Support\oculus-drivers\Oculus-Driver.exe
    When you did a clean install, are you using your Motherboard Manufacturers USB drivers, or did you just let windows do its own thing?
    Where do I find repair in the Set Up??
    I ran the \Oculus\Support\oculus-drivers\Oculus-Driver.exe however it didn't do anything.
    I had it upgraded at my local PC repair shop, unfortunately I don't know...
    Ok, do you know who your motherboard manufacturer is?
    The repair option appears if you try running the Oculus setup exe again.
    Also, if you unplug one sensor, and plug the non-working on into that port it doesn't work?
    It's Gigabyte, the manufacturer.
    I found the repair feature, it's re-downloading 4gb so i'll keep you updated once that's finished..
    It doesn't work with only the non-working sensor in :(
    Repair is finally complete... and when I went back to Set Up nothing had changed from before, still not recognising my sensor :(
    Update: I tried connecting each sensor to my laptop as well, only the working sensor registered on both USB 3.0 and 2.0 ports while the non-working sensor wasn't picked up in any way from any USB ports, so it's definitely not a hardware problem with my PC.
    Sounds like the sensor is faulty, I would issue a support ticket here to see if you can get it replaced under warranty:
    https://tickets.oculusvr.com/hc/en-us/requests/new
    Yes, please submit a ticket. If you are under warranty, we can help with a replacement. Thanks. https://support.oculus.com/
  • stickmanrunnerstickmanrunner Posts: 1
    im having the same problem and ive noticed in "device manager" under universal serial bus controllers, the non working sensor shows up as "unknown usb device (set address failed)"
