Headset USB not detecting USB 3/0 port, but sensor does
JoeyPandyJoeyPandy Posts: 2
Hello, I'm setting up my oculus rift and found that the usb for the headset for will not register the USB 3.0 on the back on my PC, but if I string a USB hub from the front USB 3/0 port, It will register that one.
I thought that maybe it was the port itself that was broken, so I plugged the sensor into it, and it registered it as a USB3.0. I would stick with using the usb hub that extends the front port, but after a while, the sound just drops completely, and I have to unplug it and plug it back in to fix it.
    Can you try using a USB 2.0 port? Also, have you updated the USB drivers for your motherboard?
  • JoeyPandyJoeyPandy Posts: 2
    I've tried using a usb 2.0 port. That doesnt work either. Only when I use the 3.0 in the front does it work.
    Yes I have updated the USB drivers of the motherboard
    It could be that USB controller is not compatible. Certain chips don't work well with Oculus. You can try getting an add-on card, see these articles for guidance.
    https://www.oculus.com/blog/roomscale-revisited-getting-the-most-out-of-your-rift/
