Oculus controller starting to get stuck.
itsdjhavicitsdjhavic Posts: 1
I can feel the trigger (trigger for pointer finger) starting to get stuck. It's not terrible but sometimes I will feel a little resistance. Is it possible to get replacement without buying a set of controllers for 100$ or is there a fix?
  • RichooalRichooal Posts: 1,441
    You could try blowing it out with a can of compressed air. I don't think I'd be using any kind of lubricant on it though.
    i5 6600k - GTX1060 - 8GB RAM - Rift CV1 + 3 Senors - 0 PROBLEMS
  • garondorfgarondorf Posts: 1
    How long have you had your controllers?
  • danknugzdanknugz Posts: 1,988
    about 3 or 4 months after i got mine, the right trigger started “sticking”, i took a close look and it turns out that the padding that goes in between the back of trigger and the plastic had come off and a piece of it had lodged ib between the seam where the trigger separates from the controller. i popped it out with a paper clip and its been fine, but i still have one that “clicks” and one that doesnt due to the loss of the padding.
    oculus said they would replace it but i would have had to send mine back in, never bothered
    A: Because it messes up the order in which people normally read text.
    Q: Why is top-posting such a bad thing?
    A: Top-posting.
    Q: What is the most annoying thing on forums?
    Please contact us. We may be able to offer replacement. Thanks.
    https://support.oculus.com/
  • SkyvvalkerSkyvvalker Posts: 1
    Same issue here and it's the right controller stick and it gets stuck to the right.
    Just emailed Oculus support; let's see what they say.  Appears to be a QC issue.
    You do not have the "same issue here".
    1. These people are talking about the original (CV1) Touch Controller.
    2. They have a sticking TRIGGER, not the joystick.
