[Solution] Fix Oculus Home Error
lowlylowly Posts: 1
Step 1: Change your system DateTime to 3/1 or even earlier.
Step 2: Open Services.msc, Restart the Oculus Rift Runtime Service.
Step 3: Open Oculus Home
Step 4: Open SteamVR
Done.
  • druffedruffe Posts: 30
    edited March 2018
    Plz wait, teh oculus chief Software Developer tried tu fix this problem, but its difficult.
    Step 5: set the time to normal
    Step 6: restart Runtime service
  • JuJuMediaJuJuMedia Posts: 1
    :s it's actually worked... but, oculus, serious?! *disappointed*
    lowly, thx!!
  • PiflyonPiflyon Posts: 21 Oculus Start Member
    Aaaand we're back to good old days where using VR was reserved to well informed hackers...  :o
    -> Have to do it each time I restart the machine
    -> An Update came today, but did not fix it. 1.24.0543697
    Thank you for this trick that worked for me :smile::smile:
    Nvidia GTX 1060, nvidia driver 391.01
  • GameStoreGamingGameStoreGaming Posts: 13
    Running your system date back can break certain applications,Windows 10 more than anything doesn't like it when you do it. DON'T. Its a colossal fuck-up on Oculus/FB part, they need to address this and fix it now.
  • lordericklorderick Posts: 1
    I have the same fucking issue. Oculus, fix this shit now!!
