HELP! OCULUS SETUP NOT WORKING!
mjb7910mjb7910 Posts: 2
I know there has been this big dispute on the inaccessibility to the Oculus Rift software which, supposedly have been resolved..but I'm not sure where my problem lies. I actually deleted my Oculus Software before I got an email about the patch. I re-downloaded the setup and have been trying to re-install the software, but I continuously get this error message telling me to restart my computer because there has been an error during installation. I've done so, and re-re-downloaded the setup after deleting the cache, everything from my C drive, but still same error. Is anyone else experiencing this?? I don't know what to do and turning my signal for help on this forum because even the error message told me to contact the support if the issue continues...please, PLEASE somebody help me!
  • LZoltowskiLZoltowski Posts: 6,560 Volunteer Moderator
  • Digikid1Digikid1 Posts: 1,583 Valuable Player
    Uninstall oculus software completely
    download and run the free trial of Ccleaner. Both cleanup AND REGISTRY a few times until it finally says no issues are found
    reboot computer
    reinstall the oculus software.
  • blanesblanes Posts: 1,067 Poster of the Week
    edited March 2018
    Don't forget to transfer your Oculus\Software directory to another Temp directory during your full un-install and cleanup as detailed above.  Then when you are ready to instal via OculusSetup,  move your Oculus\Software directory back to a directory you can create on the drive you want your games / apps to be installed to eg: E:\Oculus\   This has to be done prior to your re-install so that the installer can recognise your games directory and make the necessary installation data.
    If you do not do that then you will have to re-download your complete Oculus games library again, which is massive if you have more than a few games. Mine was 150Gb which would have taken me days with my connection.
    You probably have something running that is interfering with the setup
    Please ensure you are running the leanest version of windows possible
    Close down all non-essential applications you have such as:
    Any GPU tweaking utils such as MSI afterburner
    Any motherboard utilities such as AI suite
    Any encryption utilities
    Any SSD Utilities like Samsun Magic
    Antivirus, Antimalware
    Java updater if you have one
    Any CPU Utilities
    Any RGB peripheral utilities
    Basically running as clean a windows session as possible.
  • mjb7910mjb7910 Posts: 2
    Thank you all for your helpful insight! I'll try the solutions once I get home from work and update on here.
  • kernowkernow Posts: 732
    Finally got mine to repair by following LZ's list combined with using the installer (not the patch program) and selecting "Repair". This has been an annoying pain in the butt process to get it working again.
