Sensors will not work on Asus ROG Zenith Extreme mobo
mncrdmncrd Posts: 1
I am trying to set up the Oculus system.  I have followed the instructions and am stuck on the setup screen.  The headset is registered as OK, however the Sensors will not register.  I have tried plugging them into every single USB port.  I also tested the headset in the different USB ports and it worked in every single one.  The sensors will just not be recognized.  I see in Device Manager there are two CV1 Camera items listed which say they have no driver.
  • kroordakroorda Posts: 1
    I am having this same issue with the oculus rift set up on my razor blade laptop. Have you figured out the issue yet?
  • KNP54KNP54 Posts: 300
    edited April 2018
    I have a friend who recently bought a Rift and had the same issue! The solution was to run:
    C:\Program Files\Oculus\Support\oculus-drivers\oculus-driver.exe
    before running the setup again.
    Specs: Delidded i7-8086k @ 5.0 GHz all cores, NZXT X52 cooler, 32GB G.Skill 3200MHz, ASRock Z370 Gaming-ITX/ac, Asus GTX 1080 Strix, Corsair SF600 platinum, Samsung 970 EVO M.2 NVMe 1TB, Samgung 850 EVO 500GB + 840 EVO 500GB in raid0, Seagate Ironwolf 10TB, Louqe Ghost S1, Asus PB287Q 3840x2160 @ 60Hz, Samsung SyncMaster 226BW 1680x1050 @ 60Hz. Oculus Rift S.
  • ScootsieScootsie Posts: 1
    I had the same issue, i executed oculus-driver.exe (as mentioned above) during the installation and that fixed everything.
