Hello,
I have a 10metre HDMI extension and it will only play audio over the cable, it does not detect the oculus headset and is a black screen?I plugged the 10metre HDMI extension into a tv and displays fine as an extra screen? What can I do to make this work?
10metre usb extensions are fine and working for me
Thanks for your help
It looks like you're new here. If you want to get involved, click one of these buttons!
Answers
so it will plug between the Rift cable and your hdmi cable.
you might need a male male connector to bridge this to your current cable.
the repeater is labeled in and put at its ends make sure the end labeled IN is closest to your PC with OUT sending signals to your Rift.
I used the following
CSL - 10m UHD HDMI 2.0b Cable | 4K @ 60Hz / 2160p / 4:4:4 (High Speed) with Ethernet | ARC and CEC | Deep Color | fully HDCP compliant / HD Ready / 3D TV / Playstation 4 Pro / Nintendo Switch ecc https://www.amazon.co.uk/dp/B00KM23K5I/ref=cm_sw_r_cp_api_hQq1AbAG57568
ELUTENG HDMI Adapter Female to Female Extender 4K/1080P HDMI Repeater Signal Booster HDMI to HDMI Connector Support 3D Up to 25m for Macbook iMac DVD https://www.amazon.com/dp/B06XCZSV2Y?ref=yo_pop_ma_swf
thanks very much!
Now to sit back relax and enjoy the VR.
Who am I kidding get into it and be a kid again!
