Problem installing Oculus, error log included, please help
MattCastellMattCastell Posts: 1
Hi guys, this is the problem:
Debug] [22/04/2018 17:35:53] Installing 'Visual C++ 2013' redistributable.
[Debug] [22/04/2018 17:38:42] Process C:\OculusSetup-DownloadCache\visual-cpp-2013.exe exited with code 0 (success).
[Debug] [22/04/2018 17:38:42] Installing 'Visual C++ 2013 x86' redistributable.
[Debug] [22/04/2018 17:41:07] Process C:\OculusSetup-DownloadCache\visual-cpp-2013-x86.exe exited with code 0 (success).
[Debug] [22/04/2018 17:41:07] Installing 'Visual C++ 2015 Update 3' redistributable.
[Debug] [22/04/2018 17:41:10] Process C:\OculusSetup-DownloadCache\visual-cpp-2015-update-3.exe exited with code 1638 (success).
[Debug] [22/04/2018 17:41:10] Installing 'DirectX (June 2010)' redistributable.
[Debug] [22/04/2018 17:48:07] Process C:\OculusSetup-DownloadCache\directx-june-2010-.exe exited with code 0 (success).
[Debug] [22/04/2018 17:48:07] Installing 'Vulkan Runtime 1.0.65.1' redistributable.
[Debug] [22/04/2018 17:49:11] Process C:\OculusSetup-DownloadCache\vulkan-runtime-1-0-65-1.exe exited with code 0 (success).
[Debug] [22/04/2018 17:49:11] Install 'Dawn.Setup.InstallRedistributablesStep' succeeded.
[Debug] [22/04/2018 17:49:14] Install 'Dawn.Setup.CreateLibraryServiceStep' succeeded.
[Debug] [22/04/2018 17:49:14] Partial uninstall: False
[Error] [22/04/2018 18:00:42] Restart Manager error: Daybreak.Core.RestartManager+RestartManagerException: Error getting files in directory ---> System.IO.IOException: The file or directory is corrupted and unreadable.
   at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
   at System.IO.FileSystemEnumerableIterator`1.MoveNext()
   at System.Collections.Generic.List`1..ctor(IEnumerable`1 collection)
   at System.IO.Directory.GetFiles(String path, String searchPattern, SearchOption searchOption)
   at Daybreak.Core.RestartManager.ShutDownObstacles(String directory)
   --- End of inner exception stack trace ---
   at Dawn.Setup.CreateOculusDirectoriesStep._uninstallImpl(Nullable`1 transaction)
[Error] [22/04/2018 18:00:42] Error setting up Oculus directories: System.Exception: Error deleting stale Oculus directories
   at Dawn.Setup.CreateOculusDirectoriesStep.CreateDirectories(Nullable`1 transaction, Boolean movedSoftware)
   at Dawn.Setup.CreateOculusDirectoriesStep.InstallImpl()
[Debug] [22/04/2018 18:00:42] Install 'Dawn.Setup.CreateOculusDirectoriesStep' failed.
[Warning] [22/04/2018 18:00:42] Rolling back installation.
[Debug] [22/04/2018 18:00:42] Partial uninstall: True
[Debug] [22/04/2018 18:00:42] Uninstall 'Dawn.Setup.CreateOculusDirectoriesStep' failed.
[Debug] [22/04/2018 18:00:42] Uninstall 'Dawn.Setup.CreateLibraryServiceStep' succeeded.
[Debug] [22/04/2018 18:00:42] Uninstall 'Dawn.Setup.InstallRedistributablesStep' succeeded.
[Debug] [22/04/2018 18:02:03] Removing working directory.
[Warning] [22/04/2018 18:02:03] Exception deleting 'C:\Users\Hercules\AppData\Local\Temp\OculusSetup-29a9f0a7-c7f6-4fb1-b10b-066bb10f805c':
System.UnauthorizedAccessException: Access to the path 'DaybreakNative.dll' is denied.
   at System.IO.Directory.DeleteHelper(String fullPath, String userPath, Boolean recursive, Boolean throwOnTopLevelDirectoryNotFound)
   at System.IO.Directory.Delete(String fullPath, String userPath, Boolean recursive, Boolean checkHost)
   at Dawn.Mixins.ReallyDeleteDirectory(String path)
[Debug] [22/04/2018 18:02:03] Scheduling delete of 'C:\Users\Hercules\AppData\Local\Temp\OculusSetup-29a9f0a7-c7f6-4fb1-b10b-066bb10f805c' on next reboot.
[Debug] [22/04/2018 18:02:03] Exiting with code 1.
