How to change the battery of oculus go remote
IamnilsIamnils Posts: 2
I feel like an idiot but I can't figure out how to change the batteries of my oculus go remote. I managed to slide down the part to expose the battery but I can't get it out. Anyone with similar issues?
Thanks
  • IamnilsIamnils Posts: 2
    Thanks! turns out my battery had expanded and it's why I wasnt able to remove it.
  • maestrotmaestrot Posts: 3
    I have the same problem as described above and do not find any solution. The battery seems to be locked in the remote chassis and nothing helped to take it out of this.
  • chettawanchettawan Posts: 78
    My YouTube clip didn't help?
    @maestrot Did you check the link I posted?
    No, unfortunately it did not work. I am afraid that the battery could have expanded, so it can‘t be taken out.
    Both the link and YouTube video show exactly the way I am trying to get out the battery.
    edited June 2018
    I had an issue with taking the battery out too, it did feel like it expanded, I used a small flat head screwdriver, to gently lift the battery out on it's positive end (had to apply some force) ... it eventually popped out.
    I use a Panasonic Eneloop Pro with it now, holds a charge for 3 times the included battery had.
    Also make sure to gently push DOWN on the battery while using the screwdriver, as it's on a spring at the bottom.
    Can you please contact us for assistance? Thanks. https://support.oculus.com
    I contacted the support.
  • wegarowegaro Posts: 1
    edited July 2018
    I had the same problem, it was hard to remove but I could, had to push strongly as it the battery didn't move at all.
  • eoventoeovento Posts: 9
    edited September 2018
    I had the same issue with included battery. It took me like half an hour (and a few cuts on my hand) to take it out with a nail-scissors. If it "expanded" I don't know. What I know is that it wouldn't ever come off. And it didn't happen afterwards with decent batteries - only with the included ones.
    Yes, batteries can be slightly different sizes and unfortunately the included batteries are on the larger size. I still have some trouble replacing the batteries by hand, usually I will use a key or screwdriver and that works.
  • jedimasterkylekatarnjedimasterkylekatarn Posts: 1
    I had same issue....managed to get battery out with Flathead screwdriver, but battery damaged a bit, controller seems fine though after cleaning inside with a cloth.
  • aarondtsmaarondtsm Posts: 1
    I have same problem, can't get that battery out (Energizer AA) been using tools and jacking up battery for 15 minutes but won't push down or out, checked the instructions included, there was nothing on battery, so went to internet for help figuring I was doing it wrong, as can't imagine would require such force, but the easy click out video not how actually works. definitely a design flaw.
  • Techy111Techy111 Posts: 6,771 Volunteer Moderator
    @aarondtsm the battery goes in and also out with ease. Can you post a picture with battery in situ and cover off ?
