Echo VR has no audio, and keeps crashing when I try to join a lobby, how do I fix it?
Two issues, one post.
I can't upload crash files so here is the raw text from the crash '.txt' file:
---> Starting 2 worker threads in the scheduler.
Initializing enumerate thread: 0000011F397FFE70
Forking enumerate thread: 00007FF732F624B0 : 0000011F397FFE70
Initializing OVR session...
[CAPI] LibOVR module is located at C:\Program Files\Oculus\Support\oculus-runtime\LibOVRRT64_1.dll
Connected to the server running version (prod = 1).1.27.0(build = 604188) feature version = 0. Client runs version (prod = 1).1.27.0(build = 0) feature version = 0
[HMDState] Using default profile default
IAD changed to 62.5mm
Creating factory
OVR is specifying adapter index 0 (NVIDIA GeForce GTX 970) to create a D3D device
Successfully initialized OVR session.
Creating D3D11 device on adapter 'NVIDIA GeForce GTX 970'
Successfully created D3D11 device
Attempting to initialize NV extensions...
Nvidia driver version: r388_25 (38831)
Successfully initialized Nvidia extensions
ID3D11Device1 interface is available
Initialized GS
Loading global archives
Loading archive 0xCB3A93530D07FDC5
Loading game archives
Initializing renderer
Initializing OVR D3D components...
Creating KMTHandle 0x737d2b80
Creating KMTHandle 0x737d24f0
KMTHandle::Create hDevice=0x40000100
KMTHandle::Create hContexts[0] = 1073743040
KMTHandle::Create hContexts[1] = 1073743360
Successfully initialized OVR D3D components.
Finished initializing engine
[OVR] Logged in user app-scoped id: 838888726236426
[NETGAME] Resetting local connection stats
Loading archive 0xC6BC8607972268C9
[LEVELLOAD] Loading level '0xAC360E41E4EDE056'
[OVR] Logged in user name: spencer98881
[OVR] Logged in user org-scoped id: 1577645065590368
Unblocking monitored fence
Creating KMTHandle 0x9fe9e9c0
Creating KMTHandle 0x9fe9d930
Encountered an error:
 - 0x2FD48A8D4C79448D
  - 0x2FDA8A8C4D75508F: Error playing sound. It is not a valid wwise identifier or registered sound symbol. Either the debug data for sound symbols id not loaded (like in a final build) or someone is doing something very shady with sError playing sound 2666093702 ((null))
[LEVELLOAD] Finished loading level '0xAC360E41E4EDE056' in 1414 ms
[LEVELLOAD] Enabling level '0xAC360E41E4EDE056'
  - 0x2FDA8A8C4D75508F: Error playing sound. It is not a valid wwise identifier or registered sound symbol. Either the debug data for sound symbols id not loaded (like in a final build) or someone is doing something very shady with sError playing sound 2003371079 ((null))
  - 0x2FDA8A8C4D75508F: Error playing sound. It is not a valid wwise identifier or registered sound symbol. Either the debug data for sound symbols id not loaded (like in a final build) or someone is doing something very shady with sError playing sound 2228153899 ((null))
Prediction interval too high: 0.100007 s, clamping at 0.100000 s
ovr_SubmitFrame called with unrecognized frameIndex (4077). Make sure it matches a frameIndex value passed to ovr_GetPredictedDisplayTime
  - 0x2FDA8A8C4D75508F: Error playing sound. It is not a valid wwise identifier or registered sound symbol. Either the debug data for sound symbols id not loaded (like in a final build) or someone is doing something very shady with sError playing sound 3835684012 ((null))
  - 0x2FDA8A8C4D75508F: Error playing sound. It is not a valid wwise identifier or registered sound symbol. Either the debug data for sound symbols id not loaded (like in a final build) or someone is doing something very shady with sError playing sound 3529346668 ((null))
Creating user OVR-ORG-1
[NETGAME] NetGame switching state (from login prompt, to logging in)
Unable to perform "End" because stack is empty
Unable to perform "PopStyleColor" because stack is empty
Unable to perform "PopStyleVar" because stack is empty
Unable to perform "PopFont" because stack is empty
Unable to perform "PopTextShadow" because stack is empty
Gui warnings suspended
[NETSERVICE] SNSLoginRequest(OVR-ORG-1577645065590368): {"appid":1369078409873402,"accountid":838888726236426,"nonce":"0pYxHZO7de7zRBwCjCDlATNPpP7PJ9Kl98ZQ4WH41N5zlZHBlcJZYWjt4oUy88Nm","hmdserialnumber":"WMHD303F6004GK"}
CTcpBroadcaster: connection to wss://login.readyatdawn.com/rad/rad15_ob1 established
[NETGAME] LoginResultCB
[NETGAME] User OVR-ORG-1577645065590368 has logged in
[NETGAME] NetGame switching state (from logging in, to loading global)
[NETGAME] ClientSettingsCB
[LEVELLOAD] Loading level '0x3F9915D3001DC28E'
WaitableTimer slept too long/short (i.e. 3.064290 ms)
[SOCIAL] ovr_Room_UpdateDataStore(roomid=1915531315177179): {"seqid":0,"version":1529623784}
WaitableTimer slept too long/short (i.e. 2.530007 ms)
WaitableTimer slept too long/short (i.e. 2.271240 ms)
WaitableTimer slept too long/short (i.e. 2.038244 ms)
Prediction interval too high: 0.104813 s, clamping at 0.100000 s
[LEVELLOAD] Finished loading level '0x3F9915D3001DC28E' in 7899 ms
[LEVELLOAD] Loading level '0x4D82118C7C91B6BB'
[LEVELLOAD] Finished loading level '0x4D82118C7C91B6BB' in 168 ms
[NETGAME] NetGame switching state (from loading global, to lobby)
[NETGAME] Request Find Social Lobby
[NETGAME] Requesting finding a session of gametype 0x42D9CF9CFDDCF76 and level 0xFFFFFFFFFFFFFFFF
[SOCIAL] ovr_Room_UpdateDataStore(roomid=1915531315177179): {"seqid":1,"version":1529623784,"joinable":false}
CTcpBroadcaster: connection to wss://matchmaker.readyatdawn.com/rad/rad15_ob1 established
[NSLOBBY] server [169.254.79.129/69.88.156.91] external ip ping received after 42ms, average 42ms
[NSLOBBY] server [169.254.79.129/69.88.156.91] internal ip ping canceled
[NSLOBBY] server [10.138.0.13/35.233.149.87] external ip ping received after 46ms, average 46ms
[NSLOBBY] server [10.138.0.13/35.233.149.87] internal ip ping canceled
[NSLOBBY] server [10.138.0.11/35.203.181.60] external ip ping received after 46ms, average 46ms
[NSLOBBY] server [10.138.0.11/35.203.181.60] internal ip ping canceled
[NSLOBBY] server [10.138.0.9/35.199.166.87] external ip ping received after 52ms, average 52ms
[NSLOBBY] server [10.138.0.9/35.199.166.87] internal ip ping canceled
[NSLOBBY] server [169.254.79.129/69.88.156.91] external ip ping received after 10ms, average 26ms
[NSLOBBY] server [209.205.123.62/209.205.123.62] external ip ping received after 61ms, average 61ms
[NSLOBBY] server [209.205.123.66/209.205.123.66] external ip ping received after 61ms, average 61ms
[NSLOBBY] server [142.0.203.28/142.0.203.28] external ip ping received after 61ms, average 61ms
[NSLOBBY] server [169.254.79.129/69.88.156.91] external ip ping received after 20ms, average 24ms
[NSLOBBY] server [10.128.0.3/35.232.152.50] external ip ping received after 73ms, average 73ms
[NSLOBBY] server [10.128.0.3/35.232.152.50] internal ip ping canceled
[NSLOBBY] server [10.138.0.13/35.233.149.87] external ip ping received after 36ms, average 41ms
[NSLOBBY] server [10.138.0.11/35.203.181.60] external ip ping received after 36ms, average 41ms
[NSLOBBY] server [66.242.12.198/66.242.12.198] external ip ping received after 83ms, average 83ms
[NSLOBBY] server [10.138.0.9/35.199.166.87] external ip ping received after 41ms, average 47ms
[NSLOBBY] server [169.254.79.129/69.88.156.91] external ip ping received after 21ms, average 24ms
[NSLOBBY] server [66.242.12.202/66.242.12.202] external ip ping received after 94ms, average 94ms
[NSLOBBY] server [74.201.228.10/74.201.228.10] external ip ping received after 105ms, average 105ms
[NSLOBBY] server [209.205.123.62/209.205.123.62] external ip ping received after 55ms, average 58ms
[NSLOBBY] server [209.205.123.66/209.205.123.66] external ip ping received after 54ms, average 58ms
[NSLOBBY] server [142.0.203.28/142.0.203.28] external ip ping received after 54ms, average 58ms
[NSLOBBY] server [10.138.0.13/35.233.149.87] external ip ping received after 33ms, average 39ms
[NSLOBBY] server [10.138.0.11/35.203.181.60] external ip ping received after 33ms, average 39ms
[NSLOBBY] server [10.138.0.9/35.199.166.87] external ip ping received after 44ms, average 46ms
[NSLOBBY] server [10.128.0.3/35.232.152.50] external ip ping received after 65ms, average 69ms
[NSLOBBY] server [10.138.0.13/35.233.149.87] external ip ping received after 32ms, average 38ms
[NSLOBBY] server [10.138.0.11/35.203.181.60] external ip ping received after 43ms, average 40ms
[NSLOBBY] server [66.242.12.198/66.242.12.198] external ip ping received after 88ms, average 85ms
[NSLOBBY] server [209.205.123.62/209.205.123.62] external ip ping received after 55ms, average 57ms
[NSLOBBY] server [209.205.123.66/209.205.123.66] external ip ping received after 55ms, average 57ms
[NSLOBBY] server [142.0.203.28/142.0.203.28] external ip ping received after 55ms, average 57ms
[NSLOBBY] server [169.254.165.110/72.26.219.158] external ip ping received after 182ms, average 182ms
[NSLOBBY] server [169.254.165.110/72.26.219.158] internal ip ping canceled
[NSLOBBY] server [109.169.71.42/109.169.71.42] external ip ping received after 182ms, average 182ms
[NSLOBBY] server [10.142.0.2/35.237.94.236] external ip ping received after 183ms, average 183ms
[NSLOBBY] server [10.142.0.2/35.237.94.236] internal ip ping canceled
[NSLOBBY] server [66.242.12.202/66.242.12.202] external ip ping received after 88ms, average 91ms
[NSLOBBY] server [10.132.0.11/35.205.80.23] external ip ping received after 182ms, average 182ms
[NSLOBBY] server [10.132.0.11/35.205.80.23] internal ip ping canceled
[NSLOBBY] server [213.196.42.180/213.196.42.180] external ip ping received after 192ms, average 192ms
[NSLOBBY] server [74.201.228.10/74.201.228.10] external ip ping received after 99ms, average 102ms
[NSLOBBY] server [10.128.0.3/35.232.152.50] external ip ping received after 77ms, average 71ms
[NSLOBBY] server [66.242.12.198/66.242.12.198] external ip ping received after 88ms, average 86ms
[NSLOBBY] server [66.242.12.202/66.242.12.202] external ip ping received after 88ms, average 90ms
[NSLOBBY] server [10.128.0.3/35.232.152.50] external ip ping received after 67ms, average 70ms
[NSLOBBY] server [10.142.0.2/35.237.94.236] external ip ping received after 100ms, average 142ms
[NSLOBBY] server [74.201.228.10/74.201.228.10] external ip ping received after 89ms, average 98ms
[NSLOBBY] server [169.254.165.110/72.26.219.158] external ip ping received after 166ms, average 174ms
[NSLOBBY] server [66.242.12.198/66.242.12.198] external ip ping received after 89ms, average 86ms
[NSLOBBY] server [10.132.0.11/35.205.80.23] external ip ping received after 166ms, average 174ms
[NSLOBBY] server [109.169.71.42/109.169.71.42] external ip ping received after 166ms, average 174ms
[NSLOBBY] server [66.242.12.202/66.242.12.202] external ip ping received after 89ms, average 90ms
[NSLOBBY] server [213.196.42.180/213.196.42.180] external ip ping received after 179ms, average 186ms
[NSLOBBY] server [10.142.0.2/35.237.94.236] external ip ping received after 100ms, average 128ms
[NSLOBBY] server [74.201.228.10/74.201.228.10] external ip ping received after 100ms, average 98ms
[NSLOBBY] server [10.142.0.2/35.237.94.236] external ip ping received after 99ms, average 121ms
[NSLOBBY] server [10.132.0.11/35.205.80.23] external ip ping received after 166ms, average 172ms
[NSLOBBY] server [169.254.165.110/72.26.219.158] external ip ping received after 167ms, average 172ms
[NSLOBBY] server [109.169.71.42/109.169.71.42] external ip ping received after 167ms, average 172ms
[NSLOBBY] server [213.196.42.180/213.196.42.180] external ip ping received after 177ms, average 183ms
[NSLOBBY] server [10.132.0.11/35.205.80.23] external ip ping received after 167ms, average 171ms
[NSLOBBY] server [169.254.165.110/72.26.219.158] external ip ping received after 177ms, average 173ms
[NSLOBBY] server [109.169.71.42/109.169.71.42] external ip ping received after 177ms, average 173ms
[NSLOBBY] server [213.196.42.180/213.196.42.180] external ip ping received after 178ms, average 182ms
[NSLOBBY] server [66.242.12.198/66.242.12.198] final ping 86ms
[NSLOBBY] server [10.142.0.2/35.237.94.236] final ping 121ms
[NSLOBBY] server [66.242.12.202/66.242.12.202] final ping 90ms
[NSLOBBY] server [74.201.228.10/74.201.228.10] final ping 98ms
[NSLOBBY] server [209.205.123.66/209.205.123.66] final ping 57ms
[NSLOBBY] server [10.128.0.3/35.232.152.50] final ping 70ms
[NSLOBBY] server [142.0.203.28/142.0.203.28] final ping 57ms
[NSLOBBY] server [209.205.123.62/209.205.123.62] final ping 57ms
[NSLOBBY] server [169.254.79.129/69.88.156.91] final ping 24ms
[NSLOBBY] server [10.138.0.13/35.233.149.87] final ping 38ms
[NSLOBBY] server [10.138.0.9/35.199.166.87] final ping 46ms
[NSLOBBY] server [10.138.0.11/35.203.181.60] final ping 40ms
[NSLOBBY] server [169.254.165.110/72.26.219.158] final ping 173ms
[NSLOBBY] server [109.169.71.42/109.169.71.42] final ping 173ms
[NSLOBBY] server [213.196.42.180/213.196.42.180] final ping 182ms
[NSLOBBY] server [10.132.0.11/35.205.80.23] final ping 171ms
[SOCIAL] ovr_Room_UpdateDataStore(roomid=1915531315177179): {"seqid":2,"lobbyid":"CDB87797-E4BB-4B6E-9C68-399491028061","version":1529623784,"joinable":true,"lobbytype":0}
[NSLOBBY] connected to host peer [69.88.156.91:2000]
[NSLOBBY] destroying candidate internal host peer [169.254.79.129:2000]
R14NetClient: Destroy Peer 1 [169.254.79.129:2000] (disconnected)
Peer max send interval: 25968 (last peer=49642795 ; data=49642769 ; elapsed=12907), max recv interval:0 (last peer=49596660 ; data=49654140)
[NSLOBBY] requesting to join server with 1 players
received join accepted for 1 entrants
[NETGAME] LobbyJoinAcceptedCB
[NETGAME] Resetting replicated vars for lobby join
[NETGAME] Adding local user from entrant slot '1'
Creating encoder with bitrate of 24000
[NETGAME] Adding remote user from entrant slot '0' with useridx '1'
Player Actor Allocating '0x9E65216FB71012F2'
  - 0x2FDA8A8C4D75508F: Error playing sound. It is not a valid wwise identifier or registered sound symbol. Either the debug data for sound symbols id not loaded (like in a final build) or someone is doing something very shady with sError playing sound 4076609996 ((null))
=== System Info ===
CPU: AMD FX(tm)-6120 Six-Core Processor
Num Physical Cores: 3
Num Logical Cores: 6
Memory: 10 GB
Process Committed Memory: 3325 MB
Process Peak Committed Memory: 3343 MB
Process Working Set: 817 MB
Process Peak Working Set: 839 MB
System Committed Memory: 10183 MB
System Max Committed Memory: 14383 MB
System Physical Memory Used: 5216 MB
Video Card: NVIDIA GeForce GTX 970
Driver Version: r388_25 (38831)
Dedicated GPU Memory: 4058 MB
Answers
Leave a Comment
BoldItalicStrikethroughOrdered listUnordered list
Emoji
Align leftAlign centerAlign rightToggle HTML viewToggle full pageToggle lights
Drop image/file
