Ethernet cable via Xiaomi USB to RJ45 Ethernet LAN Adapter works on Oculus Go
benleowbenleow Posts: 7
Just want to let everyone knows that I manage to connect my Oculus Go to the network using Ethernet cable via Xiaomi USB to RJ45 Ethernet LAN Adapter. Now I can have more stable connection.
  • god_alomgod_alom Posts: 546
    Was there any special setting you had to turn on, or was it plug and play...
    Can't get mines to work. Using a cheap $2 chinese adapter.
  • DilipDilip Posts: 257
    Great feat... I found WIFI to be ok this far.... If you could enter USB Debug and use Go as RIFT let me know... I be head to heart happy.
    eh . sorry but are you the same guy as the op?
