Help with external hard drive
nypplepygnypplepyg Posts: 2
I've been using a seagate 1 tb hard drive for my media streaming over DLNA with no problems. I recently got a WD elements 2 tb drive and my oculus won't find it in the folders area in skybox or pigasus. Any help would be greatly appreciated
  • DoubirdDoubird Posts: 10
    Does your 1tb seagate have wifi connection? How were you streaming with your seagate?
  • SpuzzumSpuzzum Posts: 843
    I use a WD MyPassport 4TB drive, connected to a Raspberry Pi, connected to a hotspot created on the Pi. Make sure you actually shared the drive after swapping it in.
    Forgot to mention...did you add the drive to the Skybox app in Windows, adding the files to it's library?
    I just use 1 thing, it's the Sandisk Media Connect. You just add it to your wifi connection like you would for a laptop, ipad or phone. Then in the oculus, you go to wifi settings and connect sandisk. Then in your oculus browser the sandisk app will appear and you can just watch the videos you have on your sandisk.
    edited July 2019
    Does it act as it's own hotspot, or does it need to connect to a home network/modem in order for devices to connect? My device acts as it's own hotspot, even on a plane, train or in the bush somewhere. It might not have internet in those situations, but it'll still stream to the headset. And the 5GHz I've got it set at, is better than the 5GHz of my internet provider's modem. The headset kept dropping the 5G with the modem, telling me there's no connection. I haven't had that with my Pi...unless it was a firmware update to the Quest that fixed it. :P
    It acts as it's own hotspot. So all i need is the sandisk, turn it on and use the oculus go to watch movies stored on the sandisk. It's like having my own little wireless hard drive for the oculus.
    Cool. Reading the manual, it said to connect to your home network, not saying it was a hotspot. Thanks for clarification. My device though, as soon as I upgrade to the newer Raspberry Pi 4B, 'should' be able to capture gameplay, for recording or just to connect to a TV through the HDMI like a Chromecast device. It works with the Raspberry Pi 3B+, but it's slow as hell with only 1GB DDR2 RAM, shared between CPU and GPU. The RPi4B has as much as 4GB's of DDR4 (1, 2, and 4GB models), and supposedly capable of 4K @ 60fps.
  • SeisiuneerSeisiuneer Posts: 10
    Do you have an Amazon link for the SanDisk Media Connect device you’ve been using with your Go?
  • Techy111Techy111 Posts: 6,735 Volunteer Moderator
    Looks like this Sandisk mate = SanDisk Connect 64 GB Wireless Media Drive https://www.amazon.co.uk/dp/B00H80R5CG/ref=cm_sw_r_cp_apa_i_CvVjDb2YGEFCK
    Looking at the Sandisk Connect, the biggest capacity is 256GB. The drive in my setup is 4TB. But looking on Amazon, WD also makes a 4TB My Passport Wireless Pro. https://www.amazon.co.uk/dp/B01MT60Q7Z
    But I just realized something...the wireless MyPassport only does 802.11a...a maximum of 54Mbps. The Sandisk Connect seems to do 802.11a/b/g/n, with n being the fastest, for a maximum of 300Mbps. My Pi does 802.11ac, at a maximum 450Mbps. 4K @60 fps videos need a minimum 50Mbps over wifi, and more than that for 5K...though the Quest can't handle 5K. Just make sure the thing can handle what you want.
    the sandisk 256 is the internal memory. You can also add a micro sd card to have more memory. For me it is quite enough to store a whole lot of movies to watch on vacation etc.
  • darkphoenix12002darkphoenix12002 Posts: 1
    First, check the format of the drive as Oculus has issues with NTFS, it prefers FAT32 so you may need to reformat your drive for it to be recognized. This normally fixes most drive recognition issues.
    I don't think the Quest even has external hard drive through usb-c support, only through a NAS and wifi. Even the Oculus Go doesn't officially support external storage...yet, but you can still access files on usb through JS USB OTG, sideloaded to the Go, and it does NTFS, exFAT as well as Fat32.
    As for the NAS...it handles whatever format the drive is, and sends the files as needed. The drive attached to my Raspberry Pi NAS is NTFS.
