Using a cable to mirror the Go to another monitor?
cmeier1cmeier1 Posts: 3
I know it defeats the purpose but without any insight on a recent update in the mirroring capabilities, utilizing an HDMI plugin may be my best bet right now. Firstly, does anyone know if this would work? If so, do you have recommendations?
Thanks!
Answers
    No, that is not supported.
    edited September 2018
    You can, in a way, unofficially and using a sideloaded app via the USB cable, however, do this at your own risk and some adb knowledge is required.
    You will need to plug in into a PC obviously .. and then that to your TV for example.
    If you follow those instructions you do so at your own risk.
    Right. I should have said it's not officially supported at the moment. The trick in the video above might work for you. Also, you can Facebook Live stream to a private post on your Facebook wall and then open Facebook on your computer (I think there is about 1 second delay, but may be good enough).
