Everyone I got a situation. My oculus rift has been working for a couple of months perfectly fine and today when I went to put it on it’s starting to become choppy and I started to get poor tracking quality. As a result I reset my bro and it was still choppy so I decided to redo the full setup option. This still didn’t work I tried it a few more times and nothing. So when I decided to restart my computer and went through the rounds again, check the cables, check updates, etc. So at a last ditch effort I tried the full set up again, but when I got to the point to put the head set on it refuses to display a screen, I can’t hear anything either and the light inside of the top of the rift is orange which means it’s starting up but after waiting nothing happens. I’m out of ideas and I really need help.
Could be a software conflict. Asus software, like Sonic Suite and AI Suite, need to be uninstalled. Other software like MSI Afterburner, EVGA Precision, RivaTuner, f.lux, Team Viewer and M-Audio should be closed or disabled. You may also want to temporarily disable anti-virus and some software, like BullGuard will need to be uninstalled. Otherwise, please submit a support ticket. Thanks. https://support.oculus.com/
