What's required for a steering wheel? — Oculus
Ducati07Ducati07 Posts: 2
Hello, I've got a Razor Pro that has three USB ports so they're all taken with the headset and sensors with the Rift.
I've never seen how a wheel is attached so how does that work?
Do I need to add more USB ports to my PC to accommodate what I would assume to be more USB's?
I'd like to get the wheel, shifter, and pedals.
Thanks for any help on this topic!
  • kojackkojack Posts: 5,363 Volunteer Moderator
    If you don't have enough usb ports, you'll need to get a usb hub (a powered one is probably less likely to cause problems) to extend the number.
  • snowdogsnowdog Posts: 6,921 Valuable Player
    Yup, they connect via USB so you'll need to get a hub or PCI-E expansion card.
  • Ducati07Ducati07 Posts: 2
    Awesome, thanks!
  • dburnedburne Posts: 2,526 Valuable Player
    edited September 2018
    Yes a powered hub will work great , I have been using a CyberPower USB 2.0 powered hub for several years with great success. As kojak mentioned, be sure to get a powered one with it's own electrical plug.
    Don
    EVGA Z390 Dark MB | I9 9900k| EVGA 2080Ti FTW3 Ultra |32 GB G Skill 3200 cl14 ram | Warthog Throttle | VKB Gunfighter Pro/MCG Pro grip | Crosswind Pedals | EVGA DG 87 Case|
  • G1DD3NG1DD3N Posts: 3
    I have a Thrustmaster T150 Pro - needs a single USB to connect to.
    Is there no USBs on the front of your PC case or anything that you could connect to?
    He's got a Razer Pro. That's a laptop.
    Although it does have a usb-c port, you could use an adapter to hook a wheel up.
