Rift Audio Not Coming From Left Earpiece
TacticalBFGTacticalBFG Posts: 1
So recently I re-installed Windows (old boot record went corrupt due to some shady thing I ran.)
I installed the Oculus app again, and everything was fine for the first hour or so. Once I updated the Oculus software, my left headphone on the Rift would randomly cut out.
It might be the copper wire breaking, but I doubt that. I handle my Rift gently, and rarely adjust the headphone.
It's incredibly annoying since it barely works, and i'm hooked on Beat Saber, so once I get out I feel like i'm deaf in my left ear.
Specs: (dunno how these would help but they're sure here.)
Windows 10, 64bit, x86 based system, build 1803
GPU: Nvidia GTX 960M (I know it's not the minimum but as long as I can pull 40+ FPS i'm fine, I rarely get dizzy.)
CPU: Intel i7-6700HQ, quad core @ 2.6GHz
8GB RAM
  • lensmandavelensmandave Posts: 126
    Had a similar problem a few weeks back. First try swapping over the headphones. If you now get sound from the left side it will likely be a faulty left headphone. This was how it was for me. I contacted support and got a good outcome :)
    Intel Core i7 6700K @ 4.5GHz. Asus-Z170-PRO MB
    CORSAIR H105 HYDRO CPU COOLER.
    NVIDIA GeForce GTX1080ti. 16GB DDR4 2666MHZ HYPERX SAVAGE.
    SAMSUNG M.2 SSD 128GB SM951 Boot Drive. SAMSUNG SSD 500GB EVO Working Drive.
    Windows 10  64bit Professional
  • ElusiveMarlinElusiveMarlin Posts: 196
    I had same issue, and swapped headphones around and that sorted it for me.
    So as a 1st step I'd try that or at least tighten the retaining screw on the inside of the headband as it might just be a bit lose.
    Intel Core i7 8700K 3.7GHz | RAM 32GB DDR4 2666MHz | GeForce GTX 1080 8GB |
    240GB SATA III SSD | 3TB HDD | 867Mbps Built-in Wi-Fi
  • uKERuKER Posts: 112
    edited January 13
    Same thing started for me yesterday.
    Problem is not the headphone but probably the ribbon inside the headband.
    Created a support ticket last night, but having read experiences from other people, I'm not holding my hopes up.
