"Oculus has detected a problem with your graphics driver" possible fix, re: Nvidia + Core 2.0
LZoltowskiLZoltowski Posts: 6,774 Volunteer Moderator
edited October 2018 in General
According to reports, you may experience the rift not showing a white indicator LED and no image in the rift with the core 2.0 update and latest Nvidia drivers.
A possible fix has been reported to work for people:
Delete the file C:\WINDOWS\System32\amd-vulkan64.json if it exists.
The most common correlation between the users with the issue is that at some point they had an AMD card in their system and the json file is interfering with the Vulkan drivers that Core 2.0 is now using.
A good idea is to use the DDU tool to completely wipe your drivers out and re-instal a fresh copy.
DDU can be found here: https://www.wagnardsoft.com/
    Hey @LZoltowski thanks for posting this thread. The best way of solving this issue is to use DDU safe mode to uninstall all video drivers, including both Nvidia and AMD if you've ever used them on your machine, and then install that latest video driver for your current video card. You may also need to install the Intel graphics driver, particularly on laptops but any machine that includes an integrated GPU on the CPU may be affected (this would be most modern Intel processors). Also, it is spelled Vulkan with a "k". Thanks.
    Sorry, my startrek is showing. my auto-correct kicked in. fixed the spelling.
  • Digikid1Digikid1 Posts: 2,077 Valuable Player
    Another tool to use is CCleaner. Cleans up files that DDU leaves behind along with invalid registry entrys. Best tool ever. All you need is the free version.
    Www.piriform.com and click on CCleaner.
  • roballen321roballen321 Posts: 1
    Thank you so much for posting this! I've tried everything to fix this error, Oculus tech support were useless and I was just packing my rift up to take back to the store for Vive and I stumbled across your post and your fix worked like a charm!
    Awesome! Glad you got it sorted!
  • dosenbr0tdosenbr0t Posts: 4
    edited October 2018
    Sorry, but this doesn't solved the problem (for me).
    What is your issue?
    I get an error message in the oculus app, indicating that something is wrong with the graphic driver. The headset stays black. I already did a fresh install of the graphics driver (using the DDU Software in Safe Mode). The vulkan files are not in the directory (C:\WINDOWS\System32\amd-vulkan64.json).
    I also tried deleting the vulkan *dll and *exe files mentioned by cybereality in another post (in windows/system32 folder), and i did a repair installation of the oculus app.
    I'm also in contact with the oculus support via e-mail.
    I'm using a GTX 1070Ti (driver version 416.34) and never had an AMD Card
    I just want to play :( it's so anyoing
    Can you follow the instructions on here and attach the logs?
    https://forums.oculusvr.com/community/discussion/70097/nvidia-driver-411-63-not-rendering-to-headset-issue/p1
  • ZenbaneZenbane Posts: 15,026 Valuable Player
    edited October 2018
    Reports of this working on Facebook as well:
     Sorted! I used DDU to remove all AMD and NVidia drivers in safe mode, then installed 416.16 drivers and it's now working. Before I fitted this 1080, I had an AMD FX380, and I wonder if it might have been detecting left-over drivers from that.
    Edit: I also uninstalled Oculus Tray Tool while I was at it. Don't know if that in itself made any difference.
    Yes it was stuck to the old amd driver in the reg. Hkey_local_machine\software\khronos\vulkan\drivers and add the location of the nvidia nv-vk64.json
  • StoofnieStoofnie Posts: 5
    Pretty excited to try this, sounds like a promising fix. So many old AMD regrets!
    IT WORKED! you are geniuses. <3 Thank you!
    AWESOME! SO glad it worked.
  • wolwewolwe Posts: 1
    Nice.
    After I deleted the file, my Rift instantly worked again.
    THANK YOU. :D
    ...also: Stupid, stupid error. This should not have happened in the first place. ;)
    I got the solution (at least for me). Because i'm using a dedicated graphics card (gtx 1070ti), i deactivated the onboard intel awhile ago. I reactivated the onboard chip and now it works ... (even though the rift is plugged in the hdmi port of my graphics card)
  • bud01bud01 Posts: 169
    This fixed my problem instantly just by deleting the file C:\WINDOWS\System32\amd-vulkan64.json, closing the Oculus app, then re-opening Oculus / put headset on.
    Box had a AMD card in it for testing a while back (quadro).
    thanks other poster, good job sharing this.
  • LTkrazyLTkrazy Posts: 2
    So this is for headset issue?? And once I do thus do I need to uninstall and reinstall oculus again?
  • ThePennyCollectorThePennyCollector Posts: 4
    edited January 23
    I can't delete the files but it was working fine earlier and it just came up with the error message suddenly, and uninstalling/reinstalling didn't do anything but give me a hassle
