Problem with VR Desktop
kingBigfootiakingBigfootia Posts: 4
Since the new update I've been having some issues. Apparently it added a VR Desktop which is considered as a 4k monitor by Windows. The problem is that it's having quite an impact on my performance, also it's really annoying when pressing printscreen or opening the SteamVR overlay, since most of it is just empty area. I managed to disable it temporarily by disabling one of the experimental features, but all of a sudden it's back and I don't know how to get rid of it.
I'm also having an issue where the Oculus app immediately starts up again after I close it, it's not as bad but it's a bit annoying as well.
  • LZoltowskiLZoltowski Posts: 6,506 Volunteer Moderator
    That huge "virtual screen" is actually the rifts display, the underlying tech has changed, it's there so that the rift can display an image
  • kingBigfootiakingBigfootia Posts: 4
    Are you sure, I have a friend who also has a rift and he doesn't get it. Also the screen is just an empty desktop so I doubt it's the display.
    edited October 2018
    I have been using home 2.0 beta for a year now, always does that.
    Does your friend have the latest update and windows 10?
    He does, yeah. He even got the update before me.
    Is there at all a way to disable it though, or at least to prevent oculus from restarting itself?
