Audio popping / crackling
acefonduacefondu Posts: 5
Hello,
Had my Oculus since launch, suddenly my audio has begun crackling. This has happened before, but the issue seemingly fixed itself last time. Issue is not going away this time. Just recently upgraded to a 2080 RTX card as well, not sure if that has anything to do with it. Any help / suggestions are welcome.
I have tried the following already:
-Tightening screws on headphones
-Turning off special sounds in the windows sound settings
-Changing to CD quality audio
-Switching USB ports, tried the card not on the motherboard as well and USB 2.0 slots as well as the other 3.0 slots and even a 3.1 slot.
Thanks in advance
  • aleksejjkorobenkoaleksejjkorobenko Posts: 26
    Введите свой комментарий
  • YoLolo69YoLolo69 Posts: 1,098
    edited October 2018
    Mmmm OK so I have the same issue. It don't occurs immediately but after a while, and mainly in left ear. Yesterday it was after one our when watching a movie, and just on left ears. At the same time it crackling the 5.1 sound positional began crazy (left right reversing during 1 seconds, etc.) in the Rift headphones. Rebooting PC and problem gone for a while (so it's mostly a software problem). I also read somewhere than changing Sound property and set them to 44Khz CD quality audio may help but that didn't helped for me. It's a new problem I didn't have before. Saying that, those last months my sessions in Rift are shorter than an hour so it could be an old problem. I definitively didn't have that problem 3 months ago where sessions was longer.
    Edit : Ok I double-checked and found I didn't set CD quality 44Khz for the Rift, it was for my monitor. I changed that and will report if things are better.
    I7 3770K OC 4.6GHz, GTX1080 OC 10%, 16GB DDR3 2448  OC, Oculus Rift CV1
    Здравия вам.Имелась такаяже проблема и у моего окулус.Сейчас звук в левом наушнеке совсем перестал звучать.Думаю это нет контакта в проводке проблема не наушника, а маленьких проводочков, к сожелению
    @aleksejjkorobenko извините за продолжение на английском, гораздо больше английских ораторов вокруг:
    Nope, not in my case, as a simple reboot fixed the issue, so it's definitively software for me, not a shortcut of any sort.
  • LonzoracerLonzoracer Posts: 4
    Possible Fix:
    I also had these constant audio issues (crackles) with my Oculus Rift, tried all sort of things like using different USB ports (2.0 & 3.0), powered USB hubs, reinstalled Oculus Software, uninstalled Rift Audio driver etc. and finally FIXED IT by rolling back the Rift audio driver:
    This is how it's done (step by step):
    Left click the Windows Start Icon at the bottom left of your screen, open Device Manager - unfold Sound, video and game controllers - right click Rift Audio - choose Properties - chose tab Driver - click Roll Back Driver.
    Windows 10 then rolled back to this driver:
    Driver Provider: Microsoft
    Driver Date: 11/04/2018
    Driver Version: 10.0.17134.1
    Digital Signer: Microsoft Windows
    No more crackling audio, no matter what USB ports I use :)
    I hope this helps!
