Elite Dangerous Head Position Issue
iRoyalty-iRoyalty- Posts: 3
Hey friends,
So I am having a few issues getting my sensors setou right or my games messed or something. I have 2 sensors, they are on each side of me, roughly 3-5 feet from me and about 3-4 apart from one another. In elite dangerous when I look straight and reset my view, the ship goes on a slight angle to the right, I have to turn my head left a little and reset to get it straight but its really annoying because the games tracking is off.
I have tried pointing them straight ahead, pointed at me, recalibrated the settings and still cant get it to work. Any help or ideas would be great! Is it ok sensors overlap each other? I even tried 1 sensors on top of my monitor pointing right at me and it put it off on an angle.
  • TaomynTaomyn Posts: 28
    Funny, I've always thought it was that I needed to re-calibrate my setup because of exactly the same issue in ED, but now you're reporting the same I wonder if it's something else.
    AMD Ryzen 7 2700X CPU | Asus RoG Strix X470-I Gaming Motherboard | Corsair Vengeance RGB 32GB DDR4-3200 RAM | MSI GTX 1070Ti Gaming 8G GPU | Corsair Force MP500 M.2 120GB SSD | Samsung 860 EVO 1TB SDD | Corsair H100i v2 Cooler | Corsair 250D Case | Corsair RMx 750 80+ Gold PSU
  • iRoyalty-iRoyalty- Posts: 3
    I dont know anyone else that has the issue but then agaikn, Im new to the game so I havent found very many friends :P. Its super annoying.
    Im going to try uninstalling the software and reinstall then recalibrate everything.
  • ThmoasThmoas Posts: 293
    If in other games or oculus home centering goes OK but in ED it is off, then there is an issue with ED.
    I've been playing lately and I didn't notice this. I do use the "compensation trick" in other games (move head more to the left or up/down to recenter where I want it to be) so I don't think it's that special. In ED I move my head a bit forward.
    However, apart from this centering issue, you have another issue that it  doesn't track well? What exactly is the issue?
  • ChazmeisterChazmeister Posts: 509
    Just bind the "Recenter HMD View" or whatever they've called it, it's something like that, to a handy key or button and give that a tap when you're sat looking forwards.
  • MalicTolsenMalicTolsen Posts: 19
    Are you running Steam VR in parallel?
    It will also override your "forward" position too.
    Elites recenter HMD resets forward for me all the time, but I am also running though Oculus Home, and not using Steam VR at all, as it causes FPS drop.
    I dont think I am using Steam VR as I load it from Oculus Home. I think it may be solved. For some reason the F12 HMD reset is putting me straight and the reset I put on my joystick puts me on an angle which is a little weird.
