Center Sculpt Origin does not center my sculpt. How to center sculpt to mirror... Solved!
PoweredToastManPoweredToastMan Posts: 3
edited January 8 in Oculus Medium
Hi all I'm just trying to center my stamp to the mirror plain so i can work it? i think that should be able to do that but i currently cant the best i got was it snapping toward plain but way off center. If you know how one can align mirror and sculpt so they are centered let me know. Much Thanks.
  • PoweredToastManPoweredToastMan Posts: 3
    Ok so i found a video on you tube that has helped a lot if others are struggling with mirror and sculpt placement check this out  Thanks to Sterling77
