Problems adding Steam Games to Oculus Home with 0.85.1 Oculus Tray Tool
andyfox123andyfox123 Posts: 6
Just wondering if anyone can help me. Having to post question in new thread, as can’t post in existing one (not sure why).
I've just updated from 0.83.1 to 0.85.1, with a fresh install (no previous config retained).
I'm now having problems adding SteamVR games to Oculus Home using the new feature in 0.85.1.
In the logs I see the following when I try to add a game:
30/12/2018 19:33:32: otherAssetPath: H:\OculusSoftware\Software\StoreAssets does not exist!
30/12/2018 19:33:32: TryGetManifestFileNameAndAssetFolderList: Could not find a part of the path 'H:\OculusSoftware\Software\StoreAssets'.
30/12/2018 19:33:57: otherAssetPath: H:\OculusSoftware\Software\StoreAssets does not exist!
30/12/2018 19:33:57: TryGetManifestFileNameAndAssetFolderList: Could not find a part of the path 'H:\OculusSoftware\Software\StoreAssets'.
30/12/2018 19:33:57: Importing 'Assetto Corsa'
30/12/2018 19:33:57: Creating manifest for 'Assetto Corsa' ..
30/12/2018 19:33:57: Downloading icon header for Assetto Corsa
30/12/2018 19:33:57: game_assets_template.json not found!
30/12/2018 19:33:57: Stopping the Oculus Service
30/12/2018 19:33:59: Starting the Oculus Service
30/12/2018 19:34:00: otherAssetPath: H:\OculusSoftware\Software\StoreAssets does not exist!
30/12/2018 19:34:00: TryGetManifestFileNameAndAssetFolderList: Could not find a part of the path 'H:\OculusSoftware\Software\StoreAssets'.
The error concerning StoreAssets repeats about another 20 times, and then stops.
I've checked the path in question, and it doesn't exist in the H:\OculusSoftware or in C:\Program Files\Oculus.
These are the only two locations where Oculus software is to be found on the machine.
If this folder normally created by the Oculus software, or is it something that the Tray Tool creates. Oculus Home works fine without them, so I'm not sure why they are needed, or why they might be missing.
I was previously able to add games from Steam with no problem.
Would appreciate any thoughts on how to rectify this.
Thanks,
Andy.
  • Digikid1Digikid1 Posts: 1,492
    Ok.....so post this IN the Oculus Tray Tool thread.
