Right Controller lower trigger loose How do i fix it?
My lower trigger on my right touch controller is loose and i don't know how to fix it.
  • OculusSupportOculusSupport Posts: 954 Oculus Staff
    Hey Kellen_Dane, if the trigger button on your Touch controller is loose then this isn't likely something you'll be able to fix easily. Please create a support ticket at https://support.oculus.com so we can help you with this. Thanks! - Rick
