I need help with gear vr and my samsung note 4 update
Jakethesnake85Jakethesnake85 Posts: 1
I just factory reset my new note 4 and all of a sudden my gear vr is not updating. I just got the phone from a friend of mine and the oculus vr worked fine but all of a sudden after I factroy reset it it doesn't work. When I put the headset on with my phone and it tells me to update on the oculus app. However when I try to update it gets to 1 out of 5 then I get an error stating Could not install "Oculus Browser" and then the upates stops bringing me back to the update screen.
  • aron680aron680 Posts: 1
    Did you ever get this figured out? I'm having exact same issue on my note 4 after factory reset...
  • hdokeshdokes Posts: 1
    edited August 2019
    I am also having this same issue and I didn't even do a factory reset.  I'm being forced to upgrade and it pukes on installing the browser.... says it can not.  Can't get any further than that and can't use the head set.  I have Marshmallow 6.01 on the unit.  A little help here would be nice Oculus!
  • wam5330wam5330 Posts: 1
    edited March 28
    Did you ever beat this problem?
