Need help with focus adjustment
ImBumiImBumi Posts: 1
edited February 2019 in Oculus Rift S and Rift
Heyo, I just got my rift and had it setup. I'm not sure if I missed anything but it's very blurry for me. I have poor eyesight so it could just be me but I'm not sure if there's any software solution to adjust the focus to fit my poor eyesight. I don't experience any motion sickness or headaches from the blurriness but I just can't see properly.
I tried using it with my glasses but it's very uncomfortable because it keeps pressing it up against my face even if I adjust the straps to be very loose. Hopefully someone can point me to the right directions.
Answers
  • Spalman_ytSpalman_yt Posts: 18
    You shouldn't expect a clear crisp display, but you should be still able to read words (in the menu for example). Try placing your eyes right under the center of the lenses (the official way of wearing the Headset) and then try using the lens distance feature underneath the Headset. You could also try wearing glasses with the rift.
