Best Method for Repairing Broken Bar Mounts for Top Head Strap on CV1 — Oculus
bzowkbzowk Posts: 13
Hey Guys -
I've had my Rift CV1 since way before the touch controllers were released and love it.  A couple of weeks ago, the connector on the Rift which the top head strap loops through broke off :(.  There's a little rod which can normally be removed from two small mounts, but the issue is that the mounts on both sides are what broke off from the headset at the spots where i have arrows below...
Beyond purchasing an entire new headset, what (if any) suggestions or workarounds does anyone have to resolve this?  I've already tried superglue, Bondic, and a combination of the two; but that only lasts an hour or two at most.  I'm thinking of a different type of adhesive, replacement frame (w/o electronics if even offered), 3d printed part, or alternative method of attaching a head strap.
Thanks!
  • RedRizlaRedRizla Posts: 6,408 Valuable Player
    edited April 26
    I've just looked at mine and it does look like something that could quite easily snap. I would think about mounting something on the top of the headset, but I'm not sure what would allow something to stick there. i'm not sure if hot glue or something else would be strong enough.
    I'd like to see if someone has a proper fix even though I don't have this problem myself.
    Edit: Could you maybe wrap something around the top & bottom of the headset like strong string. Then have the Oculus strap looping around the string? Or instead of string some long plastic ties would be better.
  • bzowkbzowk Posts: 13
    Appreciate the reply and comments...
    Yea, im surprised I couldn't find more people with the issue.  Would hot glue be more adhesive than super glue?  I searched a bit more and am considering "plastic welding" where you basically melt both pieces with a soldering iron to reconnect them.  With such small parts im tedious, so still looking.  Would assume you'd need good temp control and dont have similar plastic to test with.
    If anyone else has ideas, please advise -
    Thanks
    Ask @TomCgcmfc , he has never had any issues with Oculus stuff and never goes out apparently ;)
  • vannagirlvannagirl Posts: 2,002 Valuable Player
    What’s wrong with Tom?
    he seems a great guy
    I don't know what is wrong with him either?
  • EldraadEldraad Posts: 10
    I would suggest that you 3d print (or have printed by someone) a larger version of the broken area, or a rework of it, and firmly glue it to the rift very close to the original spot (on the outer shell). Goop works quite well for things like that. I built a few things for tracking and modifying head straps when I was playing with VR and a cell phone and they held up fine.
    Another way would be to use a small bit of aluminum that is in the shape of a U, drill two holes for the Bar and use a small nut and bolt for the Pin and Paint it black. depending on the job you do it might not be noticed.
  • KingGelbinKingGelbin Posts: 3
    edited May 1
    Mine has broken multiple times. If you have all the pieces you can glue it all back together with gorilla glue but rest assured....it will break again. It's a faulty design to begin with. My next step will be to take a ring (like the ones you find on a dog collar) and attach it to the top of the mask. I can make a small base to hold the ring using any kind of plastic and gorilla glue. You can also use a acrylic denture repair kit if you can still find them. The kit comes with a powdered acrylic resin and a liquid activator solution. By mixing both together you can easily form your own components. Once the mix is set you can drill it, sand it and then set it in place either using hot glue or gorilla glue. I promise it will work for I am the gnome king and I just love to tinker.
